AZhitman Posted May 14, 2010 Report Share Posted May 14, 2010 Please and thanks much! Quote Link to comment
metalmonkey47 Posted May 14, 2010 Report Share Posted May 14, 2010 Kinda looks like an A series? But I may be wrong. Quote Link to comment
datzenmike Posted May 14, 2010 Report Share Posted May 14, 2010 Give me the number off the side of it. Youll have to wipe the grease off. Quote Link to comment
izzo Posted May 14, 2010 Report Share Posted May 14, 2010 looks like 512-60? or close to it whiteish number is 9424 Quote Link to comment
datzenmike Posted May 14, 2010 Report Share Posted May 14, 2010 Stamped into the aluminum? Quote Link to comment
AZhitman Posted May 14, 2010 Author Report Share Posted May 14, 2010 # on the matchbox module is E12-80. Quote Link to comment
banzai510(hainz) Posted May 14, 2010 Report Share Posted May 14, 2010 The modules are the same from a 210 to 280z I think its the motor that it comes from as you need the tang part that goes into the front cover for a L motor. Believe it or not a B210/210 can fit a FJ20 motor. Quote Link to comment
datzenmike Posted May 14, 2010 Report Share Posted May 14, 2010 looks like 512-60? or close to it whiteish number is 9424 No no no... clean the aluminum body off and the number is stamped into the metal. Should start with D4K (8 or 9?) then 22100 and another 5 digit number. If you get it I can tell the year and what used on. Quote Link to comment
AZhitman Posted May 14, 2010 Author Report Share Posted May 14, 2010 Gotcha - Will do, Mike. Hoping to be able to use it on my 411's R16. Quote Link to comment
