Hello710 Posted March 31, 2010 Report Share Posted March 31, 2010 hey guys i wanted to see if this was true.i was browsing on craigslist looking for parts for the ka and found an ecu that i need.its an automatic ecu but he is saying that the auto ecu works better for the 5 speed because it does not have the rev limiter.is this true? Quote Link to comment
sssr20det510 Posted March 31, 2010 Report Share Posted March 31, 2010 yes your car will act like its hitting rev limiter in 3rd 4th and 5th gear and not at 7k rpm's just ask JDM510 he had that problem Quote Link to comment
Hello710 Posted March 31, 2010 Author Report Share Posted March 31, 2010 oh alright cool.so you think it would be good to get this automatic ecu?he is asking 50 bucks :) Quote Link to comment
INDY510 Posted March 31, 2010 Report Share Posted March 31, 2010 I thought that was only for the KA24E I have never had any problems with my KA24DE......... with a #26 ECU Quote Link to comment
JDM510 Posted March 31, 2010 Report Share Posted March 31, 2010 yeah i thought i had lots of other problems but turns out it was my ECU the hole time mine would cut out all over the place barley even hit 75 mph befor it would cut out Quote Link to comment
Hello710 Posted March 31, 2010 Author Report Share Posted March 31, 2010 damn what the hell?so you think this ecu would be good for a ka24de? Quote Link to comment
INDY510 Posted March 31, 2010 Report Share Posted March 31, 2010 I don't think dual cam KAs have the problem..... I can guarantee my #26 ECU has no problems in ANY gear,,,,, , and it is a KA24DE and NOT a single cam KA24E Did you buy a KA24DE? .... I might bring my KA710 goon to the swapmeet in Fremont on the 18th........ it is probably the only KA24DE 710 in Cali........ I think the motor was mounted by Justin (the guy who built the IRS bagged 610 goon) I think the motor mounts were moved back ~1 inch or else the steering center link will hit the bell housing......... and I am going to try to fit a MadDat 180b front sump sway bar........ because the DGR 510 front sump bar will not fit a 710. If you have any questions....... I can take measurements off my car............ Do you plan to flip the front crossmember? Quote Link to comment
Hello710 Posted March 31, 2010 Author Report Share Posted March 31, 2010 oh damn dude then ur the guy to talk to.yeah man i got the twin cam just this last weekend i need to make a list of what parts i need to buy so i can start puttin it in.is the overall swap hard? Quote Link to comment
INDY510 Posted March 31, 2010 Report Share Posted March 31, 2010 Yes I didn't do the swap......... but the crossmember was flipped, motor mounts moved back, custom transmission mount, custom motor mounts, electronic fuel pump with a return line, custom radiator, electric fans, custom intake tube, tons of wiring, plugged oxygen sensor (because it will hit the steering box) ....... .. shortened driveshaft.... ... and I'm shure there is more........... you should plan on a few months and hopefully you have a welder. Quote Link to comment
Hello710 Posted March 31, 2010 Author Report Share Posted March 31, 2010 daaaaamn well i think my friend might do it for me but i want to help out.dang months?i really wanna drive my car though :( haha Quote Link to comment
inline4 Posted April 1, 2010 Report Share Posted April 1, 2010 I put a 5spd ecu in my car after having to swap the wiring harness and its a bit sluggish, but that probably has to do with clocking the distributor all over the place trying to get the car started. I have an auto ecu and a 5 spd ecu. Quote Link to comment
datzenmike Posted April 1, 2010 Report Share Posted April 1, 2010 Post the part number from it and I'll confirm that it is from an automatic for you. The single number doesn't mean anything I think. You need the pt. # For example I have an A11 B17 G04 which is for an '89 240sx manual tranny, S13 KA24E 8.6 compression. :angry: You have the KA24DE so I don't know if there is a problem with the rev limiter on them only the E type. Quote Link to comment
inline4 Posted April 1, 2010 Report Share Posted April 1, 2010 Post the part number from it and I'll confirm that it is from an automatic for you. The single number doesn't mean anything I think. You need the pt. # For example I have an A11 B17 G04 which is for an '89 240sx manual tranny, S13 KA24E 8.6 compression. :angry: You have the KA24DE so I don't know if there is a problem with the rev limiter on them only the E type. I could be convinced to go outside and swap ecus and take the car for a spin :o Quote Link to comment
