Datsun Parts Posted March 16, 2010 Report Share Posted March 16, 2010 I am looking for a OEM automatic shifter assembly and brake petal as I am converting from stick to auto. A clutch M/C delete plate would be nice too. If anyone has these parts let me know. Thanks Al Quote Link to comment
ariascarlos1990 Posted March 16, 2010 Report Share Posted March 16, 2010 I have the brake pedal. The delete plate around here somewhere to ill have to look in the daylight. Do you need the black thing that bolts to the tranny tunnel and you mount the shifter to? I have that to if so. Quote Link to comment
datzenmike Posted March 16, 2010 Report Share Posted March 16, 2010 I am looking for a OEM automatic shifter assembly and brake petal as I am converting from stick to auto. A clutch M/C delete plate would be nice too. If anyone has these parts let me know. Thanks Al Do not forget to install the spacer between the flex plate and the crank end. Without: With: . Quote Link to comment
Charlie69 Posted March 16, 2010 Report Share Posted March 16, 2010 Please post a list of all the parts you need to complete this project. I will look through my parts. I might have spacer & shifter. Used flex plate & bolts. Maybe the steel plate that goes between the block & trans these are different than the standard transmission ones. Quote Link to comment
Datsun Parts Posted March 16, 2010 Author Report Share Posted March 16, 2010 Thanks everyone for your help. Actually I am converting the complete engine and automatic transmission from a 240SX (KA24DE Fuel Injected Engine). My thoughts were to just use the OEM auto shift assembly/petal and modify it to work the linkage of the KA transmission. Quote Link to comment
zerow Posted March 16, 2010 Report Share Posted March 16, 2010 Thanks everyone for your help. Actually I am converting the complete engine and automatic transmission from a 240SX (KA24DE Fuel Injected Engine). My thoughts were to just use the OEM auto shift assembly/petal and modify it to work the linkage of the KA transmission. You need just the automatic shifter assembly that bolts to the floor? I may have an extra. I will be checking for it late in the week. You're in Rancho Cucamonga I see. May be able to deliver to you if interested... Quote Link to comment
ariascarlos1990 Posted March 16, 2010 Report Share Posted March 16, 2010 I have the brake pedal. Quote Link to comment
Charlie69 Posted March 17, 2010 Report Share Posted March 17, 2010 I noticed that you list several vehicles in your list. what vehicle are you converting? truck parts are diferent from car and z car is different from 240sx and 510. I have a shifter for a z car. Quote Link to comment
datzenmike Posted March 17, 2010 Report Share Posted March 17, 2010 Maybe the steel plate that goes between the block & trans these are different than the standard transmission ones. From what I've seen the auto ones are two piece. The bottom half is removable so you can loosen the torque converter bolts. Here are an L and a Z series from a standard tranny. One piece. Quote Link to comment
Charlie69 Posted March 17, 2010 Report Share Posted March 17, 2010 Mike is correct. the autotrans uses a 2 piece plate. Quote Link to comment
Datsun Parts Posted March 17, 2010 Author Report Share Posted March 17, 2010 I do live in Rancho Cucamonga, so PM me or email at a2602nv@yahoo.com. Cell is 909 684 8814. I am converting my 620 truck to a KA24DE engine. I need the shifter that bolts to the floor and the brake petal. Thanks Al Quote Link to comment
ariascarlos1990 Posted March 17, 2010 Report Share Posted March 17, 2010 pm sent. Quote Link to comment
Guest DatsuNoob Posted March 17, 2010 Report Share Posted March 17, 2010 Mike, are those your super sweet "re-tread" crocs? :D Quote Link to comment
Suspect Posted March 17, 2010 Report Share Posted March 17, 2010 I may also need the same stuff too, may convert a 620 to auto, got the tranny, don't have pedal, delete plate, or shifter. Quote Link to comment
datzenmike Posted March 17, 2010 Report Share Posted March 17, 2010 Mike, are those your super sweet "re-tread" crocs? :D yes........... yes they are. Wear them every day and are 6?months old now and doing just fine. That's about 1250 bicycle miles plus any walking. :D Quote Link to comment
ariascarlos1990 Posted April 5, 2010 Report Share Posted April 5, 2010 Hey just thought I'd let you know I found that Master cylinder delete plate if you want it let me know. Thanks! Quote Link to comment
