Mekanik Posted March 11, 2010 Report Share Posted March 11, 2010 This may be a dumb question but I honestly dont know. I know that Datsun made alot of parts interchangable but does anyone here know if the lower control arms from a 240z,260z, or a 280z would fit on a 1972 510? Quote Link to comment
Mekanik Posted March 12, 2010 Author Report Share Posted March 12, 2010 no one knows at all? Quote Link to comment
sssr20det510 Posted March 12, 2010 Report Share Posted March 12, 2010 looking at pics they look similar Quote Link to comment
MAG58 Posted March 12, 2010 Report Share Posted March 12, 2010 Fronts right? The dime is narrower than a Z car, so I couldn't really be sure. I can measure them when I get home tomorrow if you'd like. Quote Link to comment
thisismatt Posted March 12, 2010 Report Share Posted March 12, 2010 They do share the same ball joint apparently, so probably. 280zx for sure is not the same. The following all use the same balljoint: NISSAN 200SX (1977 - 1979) NISSAN 240Z (1970 - 1973) NISSAN 260Z 1974 NISSAN 260Z 2+2 1974 NISSAN 280Z (1975 - 1978) NISSAN 280Z 2+2 (1975 - 1978) NISSAN 510 (1968 - 1973) NISSAN 610 (1973 - 1976) NISSAN 710 (1974 - 1977) NISSAN B210 (1974 - 1978) Quote Link to comment
sssr20det510 Posted March 12, 2010 Report Share Posted March 12, 2010 the b210 ones are the same Quote Link to comment
Mekanik Posted March 12, 2010 Author Report Share Posted March 12, 2010 Fronts right? The dime is narrower than a Z car, so I couldn't really be sure. I can measure them when I get home tomorrow if you'd like. Fronts and rears... The reason I ask is because if they do fit the 510s then T3's new set of front and rear LCA's for the 240z,260z, or a 280z will fit our 510's as well Quote Link to comment
sssr20det510 Posted March 12, 2010 Report Share Posted March 12, 2010 The rears wont Quote Link to comment
Mekanik Posted March 12, 2010 Author Report Share Posted March 12, 2010 The rears wont haha boo. Ill just build some Quote Link to comment
MAG58 Posted March 12, 2010 Report Share Posted March 12, 2010 The rear of a Z is a chapman strut, which is nothing anywhere close to the Semi-trailing arm rear of the 510. The 280ZX has a really close rear suspension as does the all the x10's (excluding the H510? Not sure there) and to a lesser extent the Z31 and 910 maxima. Quote Link to comment
jesusno2 Posted March 14, 2010 Report Share Posted March 14, 2010 Your 510 ball joint info is incorrect. The 510 had 2 different ball joints one was a 11mm thread or (small taper) the other was a 14mm thread (large taper) they say that the small taper ball joints were a 68 69 thing. Which is simply untrue. My dec/1970 wagon had 11mm balljoints.I've heard people finding them in 73 sedans. Datsun was very good about using whatever the fuck they had laying around to build a car. Oh and btw I'm not 100% but I think the Z and the ZX both use 2 different length arms but, don't quote me on that I'm not a die hard Z guy. Quote Link to comment
HRH Posted March 20, 2010 Report Share Posted March 20, 2010 They are different. I know positively 510 rear lower trailing arms only fit 68-73 510s, and 73-76 610s. On the fronts, they look similar but are not interchangeable. I think they are wider and longer. You could certainly make them work with some fabrication. Quote Link to comment
