bertmobile Posted February 26, 2010 Report Share Posted February 26, 2010 I've got a '79 Datsun 620 pickup. Driving last week and the fuseable link fried (just like it's supposed to). Any ideas if it is most likely an alternator problem or maybe a voltage regulator problem? It's got 64,000 original miles. Any suggestions would be most apprecitated! Thanks! Quote Link to comment
bertmobile Posted February 26, 2010 Author Report Share Posted February 26, 2010 I forgot to mention that the truck is totally dead. No lights, horn -nothing. Battery is still charged however. Thanks! Quote Link to comment
denveratsun Posted February 26, 2010 Report Share Posted February 26, 2010 :blink: Did you replace the fuseable link? :blink: Quote Link to comment
Bleach Posted February 26, 2010 Report Share Posted February 26, 2010 That year of truck would have an internal voltage regulator in the alternator. It could be a possibility for the fusible link going out. Other causes could be a power wire somewhere grounding out causing a major load on that circuit. Have you replaced the fusible link or put a small wire on it just to test and see if power returns to the rest of the harness? Quote Link to comment
banzai510(hainz) Posted February 26, 2010 Report Share Posted February 26, 2010 I would ohm out the output post amd measure it to case of the alternator. If a straight short I say thats the proplem. I mean like less than a few ohm hopefully. A diaode shorted out. Your alternator the reg is in side as its a internal regulator type. This is what I would do. disconnect the output wire on the altarnator.(make sure not to short out to ground) Replace the fusable link or get a smaller gauge wire and put it back. disconnet the minus side of battery and put a test light inbetween the minus battery post and the cable you just took off. Get soemone/you hook the alternator output wire back up. If test light comes on a I say there is a power draw(make sure lights and door light ,dome lights are off.) But usually this would drain the battery unless this was a instant failure and saved the battery. If thats too hard for you I say get another alternator. I would clean the contacts and fuses. I think 79s had a eleltric fuel pump also. maybe clean the ground on that also. clean battery cable and the cable ground. If one has H4 lights and not using a relay it can load up the fusable link also. this is a EZ fix. Unless you added something and didnt tell us besides the fusable link did a fuse blow and IF what circut was that? Quote Link to comment
bertmobile Posted February 27, 2010 Author Report Share Posted February 27, 2010 regarding the fusable link, I replaced it w/ a wire that has a fuse installed in the middle. I hooked it up w/ a 20 amp fuse and it blew so at least I know the fuseable link will do it's job properly once I find the problem. Thanks! Quote Link to comment
datzenmike Posted February 27, 2010 Report Share Posted February 27, 2010 The '79 used a Green fusible link between battery and the rest of the truck including the alt. The Green link is rated at 40 amp. A fuse is not as good as the fusible link that can handle a short duration overload without blowing. Quote Link to comment
bertmobile Posted March 3, 2010 Author Report Share Posted March 3, 2010 good to know! Do you know what guage it would be? I found a fuseable link on line for $6 and shipping was $10 so I thought I'd give my method a try but sounds like I should replace that w/ an OEM (or similar) replacement part. Thanks! Quote Link to comment
