troyt Posted October 28, 2012 Report Share Posted October 28, 2012 '71 510 Wagon, gutted, 8-point rollcage, IRS, L20b, 280z 5 speed, 280/200 rotors, wilwoods, coilovers, r180, f/r sways, 12 gal fuel cell, plastic hood/hatch/fenders/windows, glass windshield, 14x7 panas - 2000# certified (meets min required for class) Quote Link to comment
alber garage Posted July 28, 2015 Report Share Posted July 28, 2015 Finally weighed the 510 and its pretty heavy compared to what everyone else is claiming. I used a truck scale so not sure how accurate. 2 DoorVG30DE200zx front brakes (I think)Bolt-in rollbar and rear seat100% full tank of gas2520 lbs Quote Link to comment
Son_of_a_Datsun_Guy Posted July 28, 2015 Report Share Posted July 28, 2015 Finally weighed the 510 and its pretty heavy compared to what everyone else is claiming. I used a truck scale so not sure how accurate. 2 Door VG30DE 200zx front brakes (I think) Bolt-in rollbar and rear seat 100% full tank of gas 2520 lbs That VGDE is a HEAVY motor. Like, way bigger than anything anyone else is swapping into dimes regularly. Most likely at least part of the problem you're having. Quote Link to comment
Duke Posted September 11, 2017 Report Share Posted September 11, 2017 I just posted this in my build thread, but I figured I would put it here as well to add some info to the thread. Specs: KA24de R180 280zx struts w/Willwood calipers 4 point roll bar Stripped interior (fixed bucket drivers seat, no rear seat, no carpet, no passenger seat, no heater) No bumpers All steel body panels. Many other "useless" :hmm: things removed such as high beams, horns, misc brackets, spare tire well, etc. I finally had a chance to get my car on a set of proper corner scales yesterday. I'm very pleased with the result. All it took to get the cross weights to 50/50 was two turns on the front right coilover. Also pleased at the weight with me out of the car. It would be cool to loose 50 lbs and get the car under 1900 lbs, but drastic measures might be necessary for that, and I'm not quite sure I'm ready to get that crazy. Any weight loss measures will be concentrated at the front though, at an attempt to improve the F/R weight distribution. All weights are with 1/4 tank of gas (~3 gallons, which is what I typically run when autocrossing). Total weight without me. Total_WO_Driver by Eldukerino, on Flickr Total with me. Total by Eldukerino, on Flickr Rear. Percent_Rear by Eldukerino, on Flickr Front. Percent_Front by Eldukerino, on Flickr Right front/left rear cross weight. Cross_RF_LR by Eldukerino, on Flickr Left front/right rear cross weight. Cross_LF_RR by Eldukerino, on Flickr You may notice that there is a small amount of fluctuation in the weights, I just chalk this up to "noise" in the scales and ignore it. Quote Link to comment
