lancekilgore Posted November 14, 2007 Report Share Posted November 14, 2007 Hello all out there looking for a 5 speed tranny to be shipped. Need it to mount up to a L20B 78 Datsun. My 4 speed is on the fritzs. Any help out there. I am in Peyton CO 80831 Lance Link to comment
Bleach Posted November 14, 2007 Report Share Posted November 14, 2007 It shouldn't be all too hard to find one locally. Any 1977-80 Datsun truck or 77-83 Z-car 5-speed will fit. Link to comment
Pacific coast Datsun Posted November 14, 2007 Report Share Posted November 14, 2007 Is it going into a 521 or 620? 521- will require that you modify the front flange [welded] & shortening the front shaft & trans. mount. 620- if the 4 speed is a long tail its a direct swap, just swap the trans. mounts [bolt holes r the same]. If the 4 speed is a short tail youll need to shorten the front shaft & trans. mount. Bleach has more trans. knowledge than me but are all 4 speeds long tails? Link to comment
Bleach Posted November 14, 2007 Report Share Posted November 14, 2007 Need it to mount up to a L20B 78 Datsun. Its a 1978 620 (says 620 in his profile) so its a long tail 4-speed right now. :) Link to comment
Pacific coast Datsun Posted November 14, 2007 Report Share Posted November 14, 2007 Sorry Bleach,it was a half awake post :D Yeah we have all the tranny info here! Link to comment
lancekilgore Posted November 15, 2007 Author Report Share Posted November 15, 2007 Ok there is only one junk yard in the colorado springs area that has Datsuns and I work in it on Saturdays. Last Sat I made time and searched the place the only one I found was in a 82 z22 and it won't work with out modifications. there was a 510 with one but it was messed up and would not shift. the 240 and 280zs had four speeds or automatics. The only option from there is a Automatic out of a 80 L20B. Lance Link to comment
Edz280zx Posted November 15, 2007 Report Share Posted November 15, 2007 Sorry to hijack this thread but I have a 74 620 short bed 4 speed, is it a long tail too? Link to comment
71-521 Posted November 15, 2007 Report Share Posted November 15, 2007 edz: yours should be a short tail but you would have to measure to be sure Link to comment
Bleach Posted November 15, 2007 Report Share Posted November 15, 2007 edz: yours should be a short tail but you would have to measure to be sure 1974 seems to be the transition so you need to check yourself. Datsunaholic says they are all long tail. I had a 1974 parts truck that I pulled a short tail out of. Link to comment
datsunaholic Posted November 15, 2007 Report Share Posted November 15, 2007 My '74 parts truck had a longtail in it, and the factory manual for '74 only shows the F4W71B. But... I have a '74 with a dogleg in it, which is a short transmission, but obviously not stock. If anything it has to do with the date of manufacture. Part of the problem is it's very hard to find a Datsun (especially ones in parts-truck condition) that hasn't had something changed. I've owned a total of one Datsun 620 that had the original engine still in place- and that was the parts truck. Anyhow, easy way to tell is crawl underneath. If it has a square pan on the bottom that can be unbolted, it's a shorttail 4-speed. If the tranny is cast all-round, with no steel plate it's likely a longtail (doglegs also have no bottom-plate) Link to comment
