chavezYchavez Posted January 11, 2010 Report Share Posted January 11, 2010 Guys, I am sure this has been asked before but cant find a link showing how or what is needed? I would like to upgrade the frontend on the ole datsun to bring it to the modern age any help as always is greatly appreciated. CYC 1 Quote Link to comment
JDM510 Posted January 11, 2010 Report Share Posted January 11, 2010 theirs a guy just built a ext cab 620 on 4 wheel coilovers its ALOT of work but his turned out bitchen!! Quote Link to comment
Guest DatsuNoob Posted January 11, 2010 Report Share Posted January 11, 2010 I bought QA1 proma-stars pn#4855 (or 3855, cant remember). Almost exact length as stock, extended. Check fineline's build page, he's got the same ones. Quote Link to comment
krecs Posted January 12, 2010 Report Share Posted January 12, 2010 Guys, I am sure this has been asked before but cant find a link showing how or what is needed? I would like to upgrade the frontend on the ole datsun to bring it to the modern age any help as always is greatly appreciated. CYC hey i make complete updates on 510 and z and i just got a 74 620 I will start to do the same on the 74 coilovers and disck conversion is the first step thanks. j.c. Quote Link to comment
sanitys Posted January 13, 2010 Report Share Posted January 13, 2010 I bought QA1 proma-stars pn#4855 (or 3855, cant remember). Almost exact length as stock, extended. Check fineline's build page, he's got the same ones. +1 same here Quote Link to comment
]2eDeYe Posted January 13, 2010 Report Share Posted January 13, 2010 I too have the 4855's, some welding/fabrication is required. :cool: Quote Link to comment
Eric Garside Posted January 21, 2011 Report Share Posted January 21, 2011 Are any of you guys running the 4855's also running drop spindles? Also, what size/rate of springs are you running? Thanks, Eric Quote Link to comment
sanitys Posted January 21, 2011 Report Share Posted January 21, 2011 Are any of you guys running the 4855's also running drop spindles? Also, what size/rate of springs are you running? Thanks, Eric Im using the stock spindles with beebani's 300zx caliper mounts. I have 400lb springs. Quote Link to comment
