AZhitman Posted January 8, 2010 Report Share Posted January 8, 2010 "Alice", our 67 WRL411, is about to get a fresh engine. While the engine is out being built, I'd like to rehab the suspension... it wanders pretty bad in front, and feels sloppy. I gues I could use a little guidance on parts locating and anything to look out for, as well as any tips / hints / shortcuts. Links are fine, as I don't mind doing some sleuthing... just didn't find much on our "red-headed stepchild". :) Thanks, brothers! Quote Link to comment
67411sss Posted January 8, 2010 Report Share Posted January 8, 2010 I got some stuff off this guy http://stores.ebay.com/soldonline-northbay, tie rod ends, ball joints. He was open to offers, from what i've heard the top left ball joint is unobtainable but you should be able to get everything else. Brakes are all early 510 stuff(shoes,brake lines, calipers, but the not rotor, shit i even picked up a new brake master cylinder off him for $20. Hope this helps, Rory. Quote Link to comment
Charlie69 Posted January 8, 2010 Report Share Posted January 8, 2010 What motor came in it originally? Not sure if these are the rite ones. Bottom of the page Mad Dat Suspension Parts Quote Link to comment
iscout62 Posted January 8, 2010 Report Share Posted January 8, 2010 What motor came in it originally? I'd guess it was a j13 Quote Link to comment
67411sss Posted January 8, 2010 Report Share Posted January 8, 2010 It has an R16 roadster motor with some minor changes to make it fit. Quote Link to comment
Charlie69 Posted January 8, 2010 Report Share Posted January 8, 2010 OK Thank you. Quote Link to comment
ppeters914 Posted January 9, 2010 Report Share Posted January 9, 2010 What Rory said. I've also bought stuff from that seller....very reliable and fair. Oh, it's the lower left ball joint that's unobtainium. :( As for engines: PL/WPL: J13 RL/WRL: R16 from roadster w/ a few minor differences. Quote Link to comment
67411sss Posted January 9, 2010 Report Share Posted January 9, 2010 What Rory said. I've also bought stuff from that seller....very reliable and fair. Oh, it's the lower left ball joint that's unobtainium. :( As for engines: PL/WPL: J13 RL/WRL: R16 from roadster w/ a few minor differences. Thanks Pete :D Quote Link to comment
AZhitman Posted January 9, 2010 Author Report Share Posted January 9, 2010 Not sure if these are the rite ones. Bottom of the page Mad Dat Suspension Parts That's a nice deal, but those ball joints don't look right... Pete, any idea on those? Quote Link to comment
AZhitman Posted January 9, 2010 Author Report Share Posted January 9, 2010 Here's my shopping list thus far: Shocks (F & R) Springs (going to pull out the saggy Roadster springs and go back to a different front spring... maybe the OEM ones with a coil lopped off). Tie rod ends I'm seeing NOTHING for bushings for her. Quote Link to comment
Charlie69 Posted January 9, 2010 Report Share Posted January 9, 2010 How close is the ball joint to a roadster joint? RareParts Datsun Parts Ralleye Enterprises 2 Lower Ball Joints Ebay Datsun Ball Joints 311.Org Parts Interchange. Quote Link to comment
ppeters914 Posted January 10, 2010 Report Share Posted January 10, 2010 BALL JOINTS: Unfortunately, the 410/411 ball joints are unique. Nothing else will fit. There were enough roadster folks (approx 200) willing to put down money to have the roadster ball joints reproduced by RareParts, but doubtful there's enough 410/411 owners to do the same. BUSHINGS: I figure having to match up stuff through Energy Suspension, etc. I'll worry about that after I finish the disc brake conversion and whatever else necessary to get on the road. FRONT SPRINGS: Using cut-down stock roadster springs is common to replace the 410/411 front springs. The roadster springs have to be cut-down because they're longer (10.5 inches) than the 410/411 springs (8.5 inches). I believe the stock roadster springs have a higher spring rate (approx 700 lbs/in) than the the stock 410/411 springs, but I don't know what the 410/411 rate is. It's also commonly reported that the cut-down springs become squishy/saggy. Perhaps a better option would the the shorter (+/- 9 inches), higher spring rate (approx 860 lbs/in) roadster springs sold by the roadster vendors (Mike Young, Dean @ DatsunParts.com, and Gerardo @ FairladyParts.com), however, that might put the 410/411 nose higher. Dunno. SHOCKS: KYB Options: Rear: GR2 #343135 Gas-A-Just #343135 Front: GR2 #343127 Gas-A-Just #KG4515 Sparky Pete installed the Gas-A-Justs on Bluebie, a '67 RL411, and notes: "... the fronts would be too soft with cut-down springs, causing the entertaining pogo effect over large bumps. The rears work great.". The KYB Gas-A-Just are generally stiffer. The GR2's are cheaper and great for normal street driving. Quote Link to comment
vindats1 Posted January 10, 2010 Report Share Posted January 10, 2010 "Alice", our 67 WRL411, is about to get a fresh engine. While the engine is out being built, I'd like to rehab the suspension... it wanders pretty bad in front, and feels sloppy. I gues I could use a little guidance on parts locating and anything to look out for, as well as any tips / hints / shortcuts. Links are fine, as I don't mind doing some sleuthing... just didn't find much on our "red-headed stepchild". :) Thanks, brothers! I have a few NOS ball joints, will see which ones that I have. Might have some bushings too. Will try to remember to look thru my parts. Tana Quote Link to comment
AZhitman Posted January 11, 2010 Author Report Share Posted January 11, 2010 Hi Tana - Let me know what you have for the 411 please. Mr. Peters, thanks for the info. I'm guessing we'll have to do some creative restoration on the old gal. :) Quote Link to comment
