70 521 L16 stock distributor Q????
Chris Haines
for all to know on stock dual points the wider male blade is the second set of points. meaning female wire connector that goes to male blade. and it should have a squared insulator/shield on it if it's original.
if original you can put the second points wire on the first set of points but cant put the first points wire on the second set of points.
one day i'll take a pic of this cause my explaining sounds like shit. :poop:
  • 1 month later...
  • Replies 26
Maybe later and if you can or want to get rid of them points. I installed a Petronix and they are like $85. You will need a single point distributor though, even though I heard some guy on this site that was able to convert his dual points, not sure. As far as the muffler dynamax or magnaflow. They are like $60.
