Pertronix 1741 & 1971 Dual points Dizzy
Tdatsun1971
Well Guys here goes. After many trial & errors with bad points & fouled plugs. The search was on for a Single points dist. Found one finally....but junk. Soooo i decided to modify my dual points dist. It can be done, my truck is the proof. It now runs better than ever. Plugs are great looking just the right color, no fouling. YEA! This was no big operation and it took no time at all. Matter of fact you can even line one screw up. And hook dist ground to the Pertronix plate. Hook the red & blk wire to where the kits says. Boom your done. ;)
  • Replies 10
  • 1 month later...
Anybody know if this is the same dual point dizzy that's in my 73 610? If so, I am very interested to see how you did this. I've had the same problem, looking for a single point or a cheap mathcbox, but I'd rather just go Pertronix if I could.
Thanks
Scott
I wonder how he did this as I tried to put a Pertronix on there but notice the MagnetRing of the Pertronix would be loose on the point lobes,just spin around. It would not lock down, like the point lobes on the dual point dizzy are smaller. So I cant see how he did this.
I have made L20 single point ,SSS and Mitshibishi single points work ok with the Pertronix conversions.
