thisisastickup Posted December 7, 2009 Report Share Posted December 7, 2009 How well does this work, and what's the power potential? I have a VG sitting in my garage, but I kind of want to keep the L20B. I think I could rebuild it for less than the VG swap, and have a fabricator friend build whatever metal parts I'd need. What's the cost for a decent turbo setup? What should I do to my engine when I rebuild it? What are the pros/cons of a blow-through setup? Draw-through? What parts will I need? Also, if anyone can direct me to a writeup/build thread on this, that'd be great. Quote Link to comment
MikeRL411 Posted December 7, 2009 Report Share Posted December 7, 2009 Draw through - you are sucking in an explosive mixture. If. God forbid your blower rotor hits the case [asuming it's steel] or otherwise gets in close proximity to an ignition source - BOOM. Blow through - it's only air. Nothing explosive until you get past the carb or port fuel injector. Quote Link to comment
sssr20det510 Posted December 7, 2009 Report Share Posted December 7, 2009 http://forum.ratsun.net/showthread.php?t=11371&highlight=daves+turbo Quote Link to comment
datzenmike Posted December 8, 2009 Report Share Posted December 8, 2009 Blow through: 1/ need to contain the carb in a sealed container that will handle boost pressure. Fuel pressure must be automatically adjustable to match the boost level plus 3 lbs. or else any boost will over power the fuel pump and carb will run dry. Not a worry with draw through setup. 2/ as only air is compressed an inter cooler can safely be used to lower the charge temp which increases density and reduces pre ignition. Not possible with a draw through Draw through: 1/ slamming the throttle closed on a draw through carb will cause near vacuum levels on the input side of the turbo causing oil to be sucked out through the seals on older model turbos. Quote Link to comment
Ruster Posted December 8, 2009 Report Share Posted December 8, 2009 I am wondering: (crazy question) I've seen L6 surge tanks before, but never a L4. Anyone have actual pics of a L4 surge tank setup? When I had thoughts of a off-beat turbo build for my l28 I was thinking along the lines of a blow through or draw through. Nice to see more people trying it:) -ruster Quote Link to comment
