Removing front struts Help
SpooF
  • Replies 7
The strut is only held in by the brake line, the top hat (either 3 nuts on the strut tower or the one nut holding in the shock) and two bolts on the bottom of the strut, holding it to the steering arm thing on top of the control arm/ball joint. you'll have to turn the wheel one way to access one bolt, and the opposite way to get the other.
you mean the ball joint? thats simple there are 2 ways eather you remove the 2 (17mm i beleve) bolts that go into the bottom of the strut or you remove the 2 12mm and 2 14 mm bolts and remove the ball joint with the strut
Please compress the spring, If you plan to remove the Springs. You are playing with a loaded gun. I have seen the carnage of what happens when springs are not compressed. Trips to ER, Holes in Walls, Not to mention s few broken bones. The Free height of your spring is 3"longer than it is while on the strut, Each inch of compression = say 150lbs now compress it say 3" now your talking 550lbs of pre tension, get the picture.
Please be careful.
Edited by BJW's FiveTen's
changed
