banzai510(hainz) Posted December 7, 2009 Report Share Posted December 7, 2009 (edited) a overcgarged battery will cook the water out then look good with a volt meter. but the cells die out. But usually the car wont start(load test) have a volt meter in the car helps detect certain proplems befor it Ruins something else. In my case overcharging my battery. or when your turning up the heater,headlites wipers you can see if your sytem is loading down. Edited December 7, 2009 by banzai510(hainz) Quote Link to comment
mklotz70 Posted December 7, 2009 Report Share Posted December 7, 2009 My thoughts on Skibs......even on a partially charged battery, the alt will still put out enough volts to run everything. I'm thinking that his alt is not charging...eventually, his bat gets weak, lights dim....then he hits a bump and the alt comes back online....putting out enough juice to make the lights bright. A bad connection(internally) can be good while cold, then open as it gets hot. The bump might be jarring it back into position. Quote Link to comment
lynchfourtwenty Posted December 7, 2009 Report Share Posted December 7, 2009 he changed the alt tho didnt he? Quote Link to comment
Skib Posted December 8, 2009 Report Share Posted December 8, 2009 Ill be heading over to Steve's tomorrow so hopefully well figure out whats going on. Quote Link to comment
hang_510 Posted December 8, 2009 Report Share Posted December 8, 2009 (edited) I dont have a clock? well there is your problem! you dont have time to fix it... guess its time to pull apart the harness :rolleyes: :cursing: take a close looks around bends and where it passes throught the fire wall for cuts/breaks. sounds like an almost completely broken/cut wire... Edited December 8, 2009 by hang_510 Quote Link to comment
hang_510 Posted December 8, 2009 Report Share Posted December 8, 2009 so if anyone knows where to get a 510 i will trade my 620.... maybe somebody with a bad electrical issue will??? Sounds like a loose nut behind the wheel. :D :lol: baKed... and ripped! Quote Link to comment
