RadioRedline Posted April 27, 2011 Author Report Share Posted April 27, 2011 Got Seatbelts and Taillights! Took for a Cruise...oh how I missed it! Radio Quote Link to comment
RadioRedline Posted April 27, 2011 Author Report Share Posted April 27, 2011 Heres what the Tinted Tail Lamps and Licence Plate Cover Look Like Installed...drove it to work today tee hee! Radio Quote Link to comment
RadioRedline Posted April 29, 2011 Author Report Share Posted April 29, 2011 Step 1: Clean Radio Quote Link to comment
RadioRedline Posted May 1, 2011 Author Report Share Posted May 1, 2011 Got some more decals! Radio Quote Link to comment
RadioRedline Posted May 3, 2011 Author Report Share Posted May 3, 2011 Finished 820 Wheels, and loaded up tires and them to get mounted and Balanced.. Radio Quote Link to comment
RadioRedline Posted May 4, 2011 Author Report Share Posted May 4, 2011 Paint for the 820! 12$ + 3$ + 3$ =18$ Paint Job! Tape off Saturday Night Spray on Sunday Morning Radio Quote Link to comment
RadioRedline Posted May 4, 2011 Author Report Share Posted May 4, 2011 Ok So i've been looking two different Diesels. One is a 86 one is a 82. Here are pics of the 82 which i'm leaning towards: Radio Quote Link to comment
RadioRedline Posted May 4, 2011 Author Report Share Posted May 4, 2011 Rage Gold Bodyfiller and "POR15" Came: Radio Quote Link to comment
RadioRedline Posted May 5, 2011 Author Report Share Posted May 5, 2011 Changed Oil on Benz Last Night, and Am working tonight on my Grey Truck with Brett. Radio Quote Link to comment
Cahoon520 Posted May 6, 2011 Report Share Posted May 6, 2011 Have you seen the '82 diesel start and run? If you don't buy it I might be interested in buying it. Where is it located? Quote Link to comment
muck Posted May 6, 2011 Report Share Posted May 6, 2011 Have you seen the '82 diesel start and run? If you don't buy it I might be interested in buying it. Where is it located? Here is the Kijiji ad. Kijiji ad Quote Link to comment
RadioRedline Posted May 6, 2011 Author Report Share Posted May 6, 2011 Its in the middle of nowhere 5 hours from either of us Cahoon! Radio Quote Link to comment
RadioRedline Posted May 6, 2011 Author Report Share Posted May 6, 2011 Got other door panel Finished last night. Radio Quote Link to comment
RadioRedline Posted May 6, 2011 Author Report Share Posted May 6, 2011 And a little bit of chrome... Radio Quote Link to comment
RadioRedline Posted May 6, 2011 Author Report Share Posted May 6, 2011 Painting 820 tonight I instead of Sunday because it's supposed to rain for 4 days Radio Quote Link to comment
RadioRedline Posted May 7, 2011 Author Report Share Posted May 7, 2011 Here's what happened tonight! Radio Quote Link to comment
RadioRedline Posted May 9, 2011 Author Report Share Posted May 9, 2011 820 Sold! Radio Quote Link to comment
RadioRedline Posted May 9, 2011 Author Report Share Posted May 9, 2011 Moving Forward, Will be dropping Gas Tank on Grey 620 this week, as its leaking on the seam halfway up. Any tips on doing this? I read on here that the Pitcock to drain it is in the center on the bottom. Radio Quote Link to comment
datzenmike Posted May 9, 2011 Report Share Posted May 9, 2011 You mean the petcock? doesn't have one of those but there is a bolt that can be removed to drain the fuel. Quote Link to comment
RadioRedline Posted May 11, 2011 Author Report Share Posted May 11, 2011 Yeah That! Is it more like a Drainplug? and what else to I need to look out for? Radio Quote Link to comment
RadioRedline Posted May 11, 2011 Author Report Share Posted May 11, 2011 Organized for a couple hours tonight, still not quite back to before the break-in but its coming close. Radio Quote Link to comment
RadioRedline Posted May 12, 2011 Author Report Share Posted May 12, 2011 Jacked up Back end of my 620 last night and to inspect with a light where gas is leaking from, and its right on the seam. This is what is potentially stopping me from making it to the Alberta Datsun Meet June 4. So I want to drop tank this weekend, and reweld it but I have some questions about that. I will be draining all the gas out of course, and I want to reweld the seam, and then sanblast the outside of the tank. are there any concerns with starting a fire or explosion from traces of gas or fumes? I've seen gastanks at the sandblaster, but what do I need to make sure I so before I proceed? Also held up door panel next to wood wheel for a pic of how thats coming along, and its its turning out real nice.. Radio Quote Link to comment
bananahamuck Posted May 12, 2011 Report Share Posted May 12, 2011 As goofy as this may sound that two part epoxy stuff that comes in a round log from autoparts store works real good. We have used it on 4x4s that have had pretty large rock gashes and it sealed it up and stayed sealed till tank was replaced. just make sure you smash it in your fingers till it turns a solid color and it will stink pretty bad.Just dont put over dirt and it will stick like death. To answer your question i personally would not try welding it myself.. Quote Link to comment
izzo Posted May 13, 2011 Report Share Posted May 13, 2011 Whats the tank made of, is it aluminum or tin like the body? if its tin like the body a mig wire feed should be fine turned down. But for fucks sake, i know you know this BUT.. Sparks and gas dont mix. I would take the tank as far away from your garage and wash it out after you siphon the gas out of it. Make sure you wash it good. Then get to work on it. Quote Link to comment
