low521 Posted October 24, 2007 Report Share Posted October 24, 2007 hi my name is steve i have a 1970 521 datsun pu need help have no dash lights or blinkers but have flashers brake lights running lights headlights please reply with answers thx steve Link to comment
banzai510(hainz) Posted October 24, 2007 Report Share Posted October 24, 2007 replace the fuse first!!!!!!! Did you even ck this. The fuse might look good but change them out anyway with the correct amperage. when they get old they break at the ends inside. usaully when no dash lights you have no tail lights. That was my case and replace fuse. maye clean some contacks around the fuse box. unscrew then screw it back in Link to comment
datzenmike Posted October 24, 2007 Report Share Posted October 24, 2007 As Hainz says, usually no dash... no tail lights. Switch the 4 way flasher with the signal flasher. If the signals start to work, it's a bad flasher unit... easy fix If same problem you'll have to look elsewhere. I'll have a look at my spare dash and wiring diagrams when I get home to-night. Link to comment
mklotz70 Posted October 25, 2007 Report Share Posted October 25, 2007 you can also go to http://www.the620.com and download the factory manuals on the tech page. Link to comment
