Moisabamf Posted November 18, 2009 Report Share Posted November 18, 2009 but i now have the money to do it:D well i plan to put my engine under the scalpel. i plan to put: double valve springs(Bprojects japan-rated to 10k RPM) 32mm exhaust/38mm intake valves Port and polish the head and finally the cam. BUT i need help finding a cam.... anyone have any good leads for a Cam for an a15? while this goes on, i will be cleaning up my engine bay, putting either ground control coilovers, or doing the 280zx strut swap with the big wilwood rotors and calipers, adding fender flares and etc, etc... Quote Link to comment
fisch Posted November 18, 2009 Report Share Posted November 18, 2009 I am really looking forward to folowing the progress Moisabamf! That is going to be a hot little A right there! Quote Link to comment
CharlieBucket Posted November 18, 2009 Report Share Posted November 18, 2009 i look foward to it also, i want to build a hot A15 for my B210. i thought about swaps alot but i really want to build an A-series for some reason. Quote Link to comment
hang_510 Posted November 18, 2009 Report Share Posted November 18, 2009 have you tried ISKY? call directly, they are happy to assist w/datsun projects :D (i know!) Quote Link to comment
MAG58 Posted November 19, 2009 Report Share Posted November 19, 2009 Talk to Kent cams. They've made silly amounts of power on the little brit engines the Datsun A engine was designed on (I personally had a Kent VP3 in my mini, and with 1275CC's and shared intake/exhaust that thing was still VERY motivated expecially above 4k :lol:) like the old triumphs and I'm sure they would be happy to regrind one to suit you. Oh fun fact, even though Kent is a British company, all their cams are ground/made in the states. Yes, this means if you order from kent direct they make they cam here, ship it to england, and then back to the states to your doorstep. I'd just ask if I could remove the middle man and toss it straight to the factory to keep costs down. Quote Link to comment
BJW's FiveTen's Posted November 19, 2009 Report Share Posted November 19, 2009 Try Delta Cams in Tacoma Washington. He will grind you a cam to just about any spec you want. http://www.deltacam.com He has made Cams for me in the past. No one made the cam I wanted for a Fiat Twin Cam project I did, so I had Him make the cams I wanted, this was Almost ten years ago now and they are still working well.:D Quote Link to comment
hoov100 Posted November 19, 2009 Report Share Posted November 19, 2009 delta, comp, isky, crane...etc will build you a cam to your specs. Quote Link to comment
bigjoe619 Posted November 19, 2009 Report Share Posted November 19, 2009 (edited) try schneider cams in san diego they have reground my cams for the last 15 years he knows his shit Edited November 19, 2009 by bigjoe619 Quote Link to comment
ggzilla Posted November 19, 2009 Report Share Posted November 19, 2009 Try Rick (leosnake) in LA, he's got hot tip on Datsun 1200 cams. Quote Link to comment
purple Posted November 19, 2009 Report Share Posted November 19, 2009 My engine I temporarily pulled from my car has a Schieder cam. It still looks new and is definitely made for racing. Quote Link to comment
