skunk Posted November 6, 2009 Report Share Posted November 6, 2009 any one ever put a KC rear window on a reg cab? or can some one point me to some info if there is any Quote Link to comment
Pacific coast Datsun Posted November 6, 2009 Report Share Posted November 6, 2009 Wont fit it's bigger. The KC gasket can be trimmed down & made to fit a regular cab though. Quote Link to comment
slam_dat_sun Posted November 6, 2009 Report Share Posted November 6, 2009 I was thinking about doing this but after looking at things I decided not to ..... Quote Link to comment
dat620 Posted November 6, 2009 Report Share Posted November 6, 2009 u would have to cut out the back of the cab, n put in the back cab wall from king kab, some trim fitting required, and also a good welder and body equipment would be helpful, other than that , piece of cake :D Quote Link to comment
skunk Posted November 6, 2009 Author Report Share Posted November 6, 2009 (edited) i know its biger thats kida what i was going for i was thinking just taking a KC window holding it up to the back of the cab, tracing it, grinding out the back wall to the line and slaping a gasket on it. Edited November 6, 2009 by skunktruckin Quote Link to comment
Roadracer Al Posted November 6, 2009 Report Share Posted November 6, 2009 No, windows have a "Z" shaped flange. Quote Link to comment
dat620 Posted November 6, 2009 Report Share Posted November 6, 2009 will not work, first u have a major structure support that goes accross just below the window, second u have a rear wall that is corrogated metal(wavy), third easier to do it correctly, then fighting a loosing battle for the rest of the time u own the truck, do not waste a good cab on a try of something that will leave a huge ass hole in your truck, cabs r gettin hard to find in good shape. it really only is time consuming to drill out out the spot welds, and air hammer the seams with an air chisel, then re-weld together , seal with sealer,and finish with paint, done correctly will be a mod i have not seen and also very trick, done it to a 95 yota years ago, never seen done on a 620. :) Quote Link to comment
skunk Posted November 6, 2009 Author Report Share Posted November 6, 2009 dam so i would have to mess up a KC to do this. Quote Link to comment
skunk Posted November 6, 2009 Author Report Share Posted November 6, 2009 what i really want is a roll down rear window Quote Link to comment
dat620 Posted November 6, 2009 Report Share Posted November 6, 2009 find an old limo, most used gm, or ford winders, but u still would have some mods to do to make it fit and work, there are no bolt ins... Quote Link to comment
DATSUN-FREAK Posted November 13, 2009 Report Share Posted November 13, 2009 It can b done ! Alot of work required! But very doable Quote Link to comment
72wagun Posted November 13, 2009 Report Share Posted November 13, 2009 what i really want is a roll down rear window I was talking about doing this with a friend of mine the other day. I think it would look cleaner than a rear sliding window. I'd be surprised if you could get it to fit very well in a non-KC pickup though. The seat is usually tight against the back wall (to get enough leg room). The roll down window would need some kind of mechanism to operate that would probably take away leg room. At least the way I was thinking of doing it. Maybe you were thinking of some a little different though. Quote Link to comment
datzenmike Posted November 13, 2009 Report Share Posted November 13, 2009 The KC larger window is easier to look out over your shoulder with the extended cab. Gives better visibility. However I don't like it so big and prefer the look of the smaller reg cab ones. I cut a reg cab window out and saved it for a rainy day. Some when I will try it. Quote Link to comment
skunk Posted November 14, 2009 Author Report Share Posted November 14, 2009 after looking at the trucks some more i think ill stick with the norm reg cab rear window, not going to bother with making it roll down ill just try and get a sunroof slaped on her Quote Link to comment
