fisch Posted November 9, 2009 Report Share Posted November 9, 2009 thanks By the way its never getting painted! Really!! That is fantastic!!! Bad freakin ass. I was hoping you would keep it as is, it could be as big a hit as this z car! I would love to draw your car some day. Quote Link to comment
jeremy_sr510 Posted November 11, 2009 Author Report Share Posted November 11, 2009 off to a good start, that manifold will crack even with bracing and rewelding. the issue with those manifolds are they are thin walled so in time you will buy another... for the about the price your paying for that one i can make you a top mount log manifold out of 304 SS.... check out the one i made on my 1200 if your interested... keep up the good work! Ok I'm interested so you can make one with ss flanges and 304 1/8th ss pipe, with stainless welds. ever make a log one before? any pics if you did? how long will it take you to get the parts and get'er done? is it MIG or TIG welded? is the T2 flange welded right on the top of the log or is it lifted up a little? and how much would it cost? also would have to be shipped with USPS. Thanks Jeremy Quote Link to comment
S@nt0s Posted November 11, 2009 Report Share Posted November 11, 2009 Ok I'm interested so you can make one with ss flanges and 304 1/8th ss pipe, with stainless welds. ever make a log one before? any pics if you did? how long will it take you to get the parts and get'er done? is it MIG or TIG welded? is the T2 flange welded right on the top of the log or is it lifted up a little? and how much would it cost? also would have to be shipped with USPS. Thanks Jeremy no problem, it would take me about a week to gather the material and less then a week to make and ship to you... you want the flange dead center or forward some? external gate? havent made a log but trust me its a lot easier then making mine... it will be fully tig welded let me know when you want to get started.... $280 shipped for the log to you insured and i will fix any issues you might have with it in the future Quote Link to comment
sssr20det510 Posted November 11, 2009 Report Share Posted November 11, 2009 no problem, it would take me about a week to gather the material and less then a week to make and ship to you... you want the flange dead center or forward some? external gate? havent made a log but trust me its a lot easier then making mine... it will be fully tig weldedlet me know when you want to get started.... $280 shipped for the log to you insured and i will fix any issues you might have with it in the future How much for an L series one Quote Link to comment
slodat Posted November 12, 2009 Report Share Posted November 12, 2009 S@nt0s you could get some good project funds making turbo manifolds for guys on here... Quote Link to comment
S@nt0s Posted November 12, 2009 Report Share Posted November 12, 2009 all about helping fellow guys and gals out Quote Link to comment
spoolinitup33 Posted November 13, 2009 Report Share Posted November 13, 2009 your going to need to flip the center link for the steering also cuz it will hit the bottom of the SR i had mac at mckinney do mine but looks like you weld so should not be a problem for you I didn't have to flip mine. I have an sr20 swap and stock steering and it just BARELY hits at full lock. Quote Link to comment
JDM510 Posted November 13, 2009 Report Share Posted November 13, 2009 stock motor mounts/?? Quote Link to comment
jeremy_sr510 Posted November 14, 2009 Author Report Share Posted November 14, 2009 ill get all the updates and pics up some time today motor is here! surge tank built and more.... since we are on a budget we are going with a cheap manifold for now... see how long it will last. then later down the road build one.... also bought a vw rad... looks like this one.. so the manifold... will a forward top mound fit in there? i think it will..... Quote Link to comment
fo0manchu Posted November 14, 2009 Report Share Posted November 14, 2009 yes it will but you have to fabricate up a intake pipe with some good bends and make sure you get enough distance between the maf and turbo. thats pretty much the same manifold i used on my ka24 turbo. It was suppose to be a bottom mount, i just flipped it and welded on a t3 flange. Also, my filter is on the other side of the fender well. Quote Link to comment
jeremy_sr510 Posted November 14, 2009 Author Report Share Posted November 14, 2009 just noticed the turbo will have to be taken apart then rotated.... like the one above. but then using the stock wast gate i need to make a mount or something to put the actuator back on... if it fits. Quote Link to comment
jeremy_sr510 Posted November 15, 2009 Author Report Share Posted November 15, 2009 finally an update for you guys.... front BJ's and control arm bushings... there was a little play and i had polyurethane bushings that came with the car, i had to take out the camber adjustment ones tho. kinda sucks see how it works with out them and with the bump steer spacers.... surge tank.... only paining we are doing..... sr came... Blitz bov and filter... checking out stuff.... bought spark plugs, belt, thermostat(91 sentra SE-R), and oil filter, also more gauges for the car.... tonight I changed the thermostat, took off the oil pan cleaned it and tapped out the little dent, turbo and manifold off, pulled the trans to check out the clutch. One problem the harmonic balancer was coming apart. called jdmsource and told him. He seemed surprised, sent them pics of it they said they would get me one. I was very surprised how clean it was. nice to work on. Every nut and bolt just comes off like its new. Quote Link to comment
jeremy_sr510 Posted November 21, 2009 Author Report Share Posted November 21, 2009 update... new main seals front/rear, ngk plugs Waiting on parts in the mail..... -Fuel pump Walbro inline 255 -exedy clutch kit -valve cover and exhaust/turbo manifold gaskets -water pump -proper sr20det thermostat -oil filter sandwich -Bings aluminum pulleys also picked up 14 tight radius mild steel elbows, and will be getting the flanges laser cut, next week... see what we can make up... next big buy will be a FMIC kit, any suggestions for what kits to buy or what intercoolers? 2.5" piping? Quote Link to comment
jeremy_sr510 Posted December 27, 2009 Author Report Share Posted December 27, 2009 another update... coming together! new parts installed -Fuel pump Walbro inline 255 -exedy clutch kit -valve cover gasket -water pump -thermostat -oil filter sandwich, came with wrong adapters, had to machine and rethread, but also now i can use bigger filters. -Bings aluminum pulleys -fuel lines bassicly all done. motor is now sitting in the car today i plan to make motor mounts and trans mount. Quote Link to comment
jeremy_sr510 Posted December 27, 2009 Author Report Share Posted December 27, 2009 (edited) also sway bar installed, came with bushings but no clamps so i used my old clamps and had to drill out my 7/8th bushings... motor mounts i found at work... verry hard, same thickness as stock L series mounts, should work with couple washers. Edited December 27, 2009 by jeremy_sr510 Quote Link to comment
fisch Posted December 27, 2009 Report Share Posted December 27, 2009 Still lovin the hell out of this man!! That surge tank is teh bees knees. I jsut read this quote on speedhunters, and I thought you would like it. "The type of people that modify their cars to have this "rat" look don't purposely do it. They get these cars looking ragged and beat up. But rather than fixing it up to be clean and hiding the wear, tear, and most importantly, it's history, they choose to keep all that exposed. Why hide history? History builds character. If you build from history, you'll find that you're always in a better place." Quote Link to comment
jeremy_sr510 Posted December 27, 2009 Author Report Share Posted December 27, 2009 ya thats a good one.. motor is now in. used my stock mounts with shims, made a trans mount... pics tomorrow camera's dead now. Quote Link to comment
ANM21977 Posted December 30, 2009 Report Share Posted December 30, 2009 SANTOS, I have a 1971 2dr 510 that I am doing the same swapp please pm me so we can discuss the possibity of you fabing a top mounted manifold for my sr20det. Ialso have some questions if you dont mind. off to a good start, that manifold will crack even with bracing and rewelding. the issue with those manifolds are they are thin walled so in time you will buy another... for the about the price your paying for that one i can make you a top mount log manifold out of 304 SS.... check out the one i made on my 1200 if your interested... keep up the good work! Quote Link to comment
JDM510R Posted January 3, 2010 Report Share Posted January 3, 2010 What a nice Project you got going. Any updates? Quote Link to comment
jeremy_sr510 Posted January 3, 2010 Author Report Share Posted January 3, 2010 try and get more pics today. couple fuel lines to hook up today, take the motor back out drill hole for wiring in the firewall, put an elbow on the heater core so we can get that hooked up, ordered an inline coolant filler from csr-performance. trying to figure out what to do for a turbo now, my stock t25 doesn't want to clock... Quote Link to comment
jeremy_sr510 Posted January 4, 2010 Author Report Share Posted January 4, 2010 just mount this manifold and down pipe, ill get a good t25, t28 or gt28... use it tell it cracks or falls off the car. then build a manifold.... more pics... Quote Link to comment
jeremy_sr510 Posted January 7, 2010 Author Report Share Posted January 7, 2010 Now the fun part :lol: .... not really... picked this up today.... will 3 of these work?.... where does the blue plug go?.......jk i know that one, but do i cut into the little plug there? O2 sensor... ignitor/ egr sensor / wastegate valve control solenoid do i need all of this? i will be using stock t25 on a top mound with stock wastgate... not sure.... 1 not sure...2 i need the fuse from inside this fuse box...? also not sure again. the other two with the maf get used? after i figure out that ill need to figure out what i can cut off this mess... Quote Link to comment
sycloned916 Posted January 7, 2010 Report Share Posted January 7, 2010 Ignitor yes. I got rid of the egr and boost sensor works fine for me. Look for the plug with the 7-8 wires you need on Pg#1,i think the plugs are on the wires with the two cylinders things on it,I'll check mine in abit. Just go by the print out and you'll be fine. I just cleaned you the rest of the wires not used and tucked them up and away! Quote Link to comment
jeremy_sr510 Posted January 7, 2010 Author Report Share Posted January 7, 2010 Ignitor yes. I got rid of the egr and boost sensor works fine for me. Look for the plug with the 7-8 wires you need on Pg#1,i think the plugs are on the wires with the two cylinders things on it,I'll check mine in abit. Just go by the print out and you'll be fine. I just cleaned you the rest of the wires not used and tucked them up and away! are you using stock turbo and wastegate? Thanks Jeremy Quote Link to comment
