Eagle_Adam Posted May 25, 2013 Report Share Posted May 25, 2013 Trololololol, kami....... I'm Gunna try anyway ;) 1 Quote Link to comment
Eagle_Adam Posted May 25, 2013 Report Share Posted May 25, 2013 Called Baxters, napa, and both discount stores.... Only cork available... What am I missing here kAmi? Quote Link to comment
Eagle_Adam Posted May 25, 2013 Report Share Posted May 25, 2013 Fuck it, it's going in im outta time and patience Purple oil for a purple motor.... Seems legit 3 Quote Link to comment
mklotz70 Posted May 26, 2013 Report Share Posted May 26, 2013 Adam....let me know when you want to bring a rim over. Quote Link to comment
MicroMachinery Posted May 26, 2013 Report Share Posted May 26, 2013 Enough of this foreplay. I wanna hear that sumbitch run! 1 Quote Link to comment
Eagle_Adam Posted May 26, 2013 Report Share Posted May 26, 2013 I wanna hear it run too!!! I had help lined up for today but he bailed so I was forced to work on things to keep me busy... Deleted a bunch of unneeded wiring from the engine bay Painted the metal housing that the washer fluid mounts to And got the Altima alt ready to put in, just had to swap pulleys, shorten the spacer and tag the nut in place And now I'm on my way home to drop these in 1 Quote Link to comment
Spoona_Jay21 Posted May 26, 2013 Report Share Posted May 26, 2013 Lovin the progress! Quote Link to comment
Eagle_Adam Posted May 26, 2013 Report Share Posted May 26, 2013 Motors in, trans is in, driveshaft is in, Redbanner is a bawse, it's 4 am, and I'm going to bed... 2 Quote Link to comment
Eagle_Adam Posted May 27, 2013 Report Share Posted May 27, 2013 Mike, if I can get my truck running again ill stop by tomorrow. Quote Link to comment
Eagle_Adam Posted May 27, 2013 Report Share Posted May 27, 2013 Rads in, grills in, hoses and wires are all hooked up. Other than a heater corr hose isse, we Just need to fill with fluids, bolt on the SU's, and see what happens! Quote Link to comment
Eagle_Adam Posted May 28, 2013 Report Share Posted May 28, 2013 thermostat and heater core hoses are in, just need to re-install the exhaust, fill the fluids, attach the carbs and linkage, and test fire this sucker!!! Quote Link to comment
Eagle_Adam Posted May 28, 2013 Report Share Posted May 28, 2013 To Do Before Canby: find a Thermostat housing plug for the vaccumm thingy... Su's cleaned drop off Exhaust mani to get bead blasted and surfaced Exhaust painted and put on Trans plate cleaned and painted Fuel pump nuts Alternator upgrade Clean the fan adjust the Valves replace Heater core hose Re torque bolts (all of them) Paint oil dip stick Paint heater core fitting on cylinder head Install thermostat Clean and Install dizzy stall the motor plum and wire engine bay clean/degrease engine bay Buff and wax Carpet Plate for passenger floor install the SU's Hub caps - clean and paint Stereo install new front Brakes Quote Link to comment
Eagle_Adam Posted May 29, 2013 Report Share Posted May 29, 2013 Bought some new rims that will clear the big breaks klotz has in the works! 3 Quote Link to comment
mklotz70 Posted May 29, 2013 Report Share Posted May 29, 2013 Bought some new rims that will clear the big breaks klotz has in the works! .....uummm......you mean ready to mount? The first set if finished. :) Quote Link to comment
Eagle_Adam Posted May 29, 2013 Report Share Posted May 29, 2013 :w00t: :w00t: :w00t: :w00t: :w00t: :w00t: should have rims by friday and tires by monday if all goes well!!! Quote Link to comment
Eagle_Adam Posted May 29, 2013 Report Share Posted May 29, 2013 WOOT WOOT!!! new tires are on order too! Should be here next week some time! Quote Link to comment
Eagle_Adam Posted May 31, 2013 Report Share Posted May 31, 2013 jessi stopeed by the JY to pick up some wiring harness plugs from an altima so we could wire in the alt Quote Link to comment
RedBanner Posted June 1, 2013 Report Share Posted June 1, 2013 I only had to build one piece for my whole manual swap. Just a bracket for the clutch peddle spring. Took 3 minutes. For your record I used. A 610 trans crossmember, Long tail trans. 510 peddles. Hard line from a 610, there are 2 styles for the 710, pre76 ones are identical to the 610 ones, later ones hug the brake lines and look alot cleaner than the early ones wich snake alover and under the throttle. I have one of each lines you could mimmick when the time comes. Cool wheels yo! And you guys are doing great! Quote Link to comment
Eagle_Adam Posted June 1, 2013 Report Share Posted June 1, 2013 Thanx banner, should be firing her up tomorrow. ;) should come see her roar to life :) Quote Link to comment
MicroMachinery Posted June 1, 2013 Report Share Posted June 1, 2013 It's tomorrow... 3 Quote Link to comment
Spoona_Jay21 Posted June 1, 2013 Report Share Posted June 1, 2013 quite fancy wheels! once those are on, make it lower with the JDM front bumper, (and the factory grille) and it will be perfect! Quote Link to comment
MicroMachinery Posted June 2, 2013 Report Share Posted June 2, 2013 ... well? 1 Quote Link to comment
Eagle_Adam Posted June 2, 2013 Report Share Posted June 2, 2013 Was one coolant line away from firing it up last night...... This motor has an A87, the carbs were on a u67. Had to find a fitting and then couldn't find the right line in the garage. Just got up, like still in bed..... Gunna round up parts and BBQ supplies and get to it!! Quote Link to comment
RedBanner Posted June 2, 2013 Report Share Posted June 2, 2013 I hope to be headed up for a quick smash and grab on that exaust. Later this afternoon. Quote Link to comment
Eagle_Adam Posted June 2, 2013 Report Share Posted June 2, 2013 Winning!! Come by whenever man Quote Link to comment
