athoose Posted November 2, 2009 Report Share Posted November 2, 2009 I need bushings for my 200sx dizzy. I have a choice of .627 Quote Link to comment
banzai510(hainz) Posted November 2, 2009 Report Share Posted November 2, 2009 partsamerica.com rockauto.com Quote Link to comment
athoose Posted November 2, 2009 Author Report Share Posted November 2, 2009 partsamerica.com is no more Rock Auto, Oreilly's, NAPA all give me a choice of .627 and .6299 for both the top and bottom bushing. I noticed they offer the same choice for the 280zx as well, apparently it is the same size as the 200sx. Also I saw a website awhile ago about a Z guy who was making the bushings, if anyone has that link let me know. Quote Link to comment
banzai510(hainz) Posted November 2, 2009 Report Share Posted November 2, 2009 .oo2 is minimal. if anything on the slop. order both? Quote Link to comment
Colbino Posted November 2, 2009 Report Share Posted November 2, 2009 I'm in the process of rebuilding my distributor too, but what bushings are you speaking of? Do you mean shims? Because as far I can tell I just need one or two more shims to remove the slop. Hope I didn't thread Jack. Quote Link to comment
athoose Posted November 2, 2009 Author Report Share Posted November 2, 2009 I'm in the process of rebuilding my distributor too, but what bushings are you speaking of? Do you mean shims? Because as far I can tell I just need one or two more shims to remove the slop. Hope I didn't thread Jack. The bushings pressed into the dist. body that the shaft spins in. If you have wobble/play in your shaft (side to side) you need these. Quote Link to comment
athoose Posted November 2, 2009 Author Report Share Posted November 2, 2009 The bushings pressed into the dist. body that the shaft spins in. If you have wobble/play in your shaft (side to side) you need these. Actually, I don't know if your 72 has these. Maybe someone can chime in for certain. Quote Link to comment
hang_510 Posted November 2, 2009 Report Share Posted November 2, 2009 on all the reman ive seen, theyre metal, all the OEM have plastic...maybe thats the diff??? Quote Link to comment
Colbino Posted November 2, 2009 Report Share Posted November 2, 2009 I'll have to look closer, but I didn't see anything that was rubber or plastic. As I recall, the play I had was up and down, or vertical, and not side to side, Is that common? Quote Link to comment
