Sealik Posted October 27, 2009 Author Report Share Posted October 27, 2009 (edited) Well.... just got one of the 720s home Was a long day... Snapped some pics..... Noticed some other things on it after the fact.....bonus. Has those switches in the tray that Steve mentioned. Rear slider in cab. New exhaust. Have the paper work....was sold in Edmonds, Washington in 1989 for 5500 cash. From the listed price of 6995......with 144,347 miles. Was brought to Canada right after the sale....has 151+ on it now. So it has about 7000 miles on it after it was purchased in the US Not bad....got 380 (80 to tow) into it now. Should be able to finish it for under 400.LOL Have the parts......windshield....hood and valance.....even the same color! Anywho.... Edited October 27, 2009 by Sealik Quote Link to comment
izzo Posted October 27, 2009 Report Share Posted October 27, 2009 id like that center console switch panel if he dont Quote Link to comment
Sealik Posted October 27, 2009 Author Report Share Posted October 27, 2009 id like that center console switch panel if he dont Will keep that......since I have no others. Just need some lights.:D Quote Link to comment
steve g Posted October 27, 2009 Report Share Posted October 27, 2009 that switch panel means it either came with a push bar or roll bar with lights, but if it came with bolth it would have had 2 green switches Quote Link to comment
Sealik Posted October 27, 2009 Author Report Share Posted October 27, 2009 There are mounting holes on the guard......push bar. Quote Link to comment
Sealik Posted October 27, 2009 Author Report Share Posted October 27, 2009 Which would make one conclude that the guard is.....? Factory? Quote Link to comment
steve g Posted October 27, 2009 Report Share Posted October 27, 2009 the pushbar you have is dealer installed not "factory installed" Quote Link to comment
steve g Posted October 27, 2009 Report Share Posted October 27, 2009 OR OR OR OR........ look in the bed for roll bar holes!!!!!!! Quote Link to comment
Sealik Posted October 27, 2009 Author Report Share Posted October 27, 2009 Give me 12 min....shall snap a pic Quote Link to comment
Sealik Posted October 27, 2009 Author Report Share Posted October 27, 2009 Well ....I can't really see in the bed....canopy and all:) Looks like there was a tonneau/bed cover on it at one time Here are the holes for the lights. And the tray....again Quote Link to comment
Sealik Posted October 27, 2009 Author Report Share Posted October 27, 2009 Thing is....that truck hasn't been washed and or touched, in many...many moons. Shall look a little 'different' in a week.... Quote Link to comment
Sealik Posted October 27, 2009 Author Report Share Posted October 27, 2009 (edited) So....I have "off road lights" and "fog lights"....off/kc/on. Can't all be mounted on the upper part of the guard. Correct? Gonna assume there are at least 4 lights. Hmmmm. Edited October 27, 2009 by Sealik Quote Link to comment
Sealik Posted October 29, 2009 Author Report Share Posted October 29, 2009 Well...I got the 720 running.....finally Couldn't figure out why no gas would come out of the fuel tank. Changed the relay, fuses....and then the pump. Still nothing....then I pulled the hose off the side of the tank and hit it with some air.....nothing....totally blocked. Stuck a wire in about 7 inches and auged it out. Finally....I could blow air into the tank. But why.....???? They said the truck was ran out of fuel.....not. Smells like varnish. Changed the accelerator pump because it was leaking.... I assumed. Not....was coming from the top of the carb Pulled the front of the carb off and cleaned it up......needle was stuck. Lots of crud. Put another filter before the carb so I could flash it up and move it into my 'shop'. Obviously the tank is full of shit....which is why the fuel sending unit is NFG. I'll drop the tank and clean it out, but....I could use some knowledge on this endeavour. Thanks Quote Link to comment
Sealik Posted November 6, 2009 Author Report Share Posted November 6, 2009 Update.... Changed the windshield, 'windshield wiper' valence, passenger window, gas tank (cleaned up) and found another sending unit in my back fourty:cool: Installed a front driveshaft....was missing. Replaced the ignition switch (soldered in) and plastic pieces that cover the steering column. Replaced the heater switch/harness (soldered in), and cover for switches. Pulled the seat and carpet.....dryed them out....shall install on weekend Changed the fluids Replaced thermostat and installed block warmer. Changed the tires and rims Gave it a quick wash.....but needs a good pressure wash. Just realized that it's a long bed...:lol:...wanted to put on a better canopy I have....but no fit.:confused: Mine are all for short beds Still much to do.... Quote Link to comment
izzo Posted November 6, 2009 Report Share Posted November 6, 2009 did you change the hood also? The pics above it shows rust on the hood and some dings, then the final picture doesnt Quote Link to comment
Sealik Posted November 6, 2009 Author Report Share Posted November 6, 2009 Yes.... the hood......and hinges Pretty sure the hood went through the windshield. It has a couple of dings in it.....(from me) Was covering up another front end of a truck....didn't think I would ever need it. Being that I have about 11 out side...:lol:.... It was the only one I had that matched the color of the truck Quote Link to comment
Sealik Posted November 6, 2009 Author Report Share Posted November 6, 2009 I also replaced the back bumper.....shall paint it ...again...in the spring Quote Link to comment
izzo Posted November 6, 2009 Report Share Posted November 6, 2009 Should hook me up with a couple of em, even it out a bit. I only have 3 :lol: Quote Link to comment
Sealik Posted November 6, 2009 Author Report Share Posted November 6, 2009 Well.....drop by then.....:lol::lol: I'm having a free pick n' pull.:rolleyes: I also removed some of the unstable black crap on the floor and slathered. Moisture gets under there....not good. Also....have to mount one of my Datsun radios. Would of been rather costly for someone to fix this truck.....if they didn't have all the parts....as I. Quote Link to comment
Sealik Posted November 6, 2009 Author Report Share Posted November 6, 2009 That pic reminds me of the kicks....paper. Not good Have some nice black plastic ones for this 'restore'. Quote Link to comment
Jester Posted November 6, 2009 Report Share Posted November 6, 2009 Wow. That truck is cleaning up rather nicely. Too bad it's not a KC. Quote Link to comment
Sealik Posted May 16, 2010 Author Report Share Posted May 16, 2010 Update..... Made a few changes...... :cool: Quote Link to comment
Sealik Posted May 16, 2010 Author Report Share Posted May 16, 2010 Charcoal beige metallic......sort of. Shall return to painter..... Right color....bad app. :angry: Quote Link to comment
