ratsar_nx Posted September 25, 2009 Report Share Posted September 25, 2009 Today I decided to take out the panels inside my trunk to try and fix the remote release for my gas door. As with nearly every car project, what seems like a small job ends up turning into something way bigger. I took the trunk liner panels out and found some rather serious rust problems. This is what the right side looks like.: The hole is bigger now after pulling off some of the rusted metal This is the left side: After removing some of the rust, there is a hole there almost as big as my fist. This is on an '86 Pulsar, which is a unibody car. Given the location of this rust, does that look like a structural area to anyone else? What is the best way to deal with this? I do not own a welder or have access to one. I do know one person who I can ask, but I don't know if they would be willing to help me or not. All of this would involve welding directly over the gas tank and the filler neck is about a foot away from where you would be welding on the right side, just out of view in the first picture. The other option I'm considering is to remove all the rusty metal and patch with fiberglass. Quote Link to comment
Skib Posted September 25, 2009 Report Share Posted September 25, 2009 take out your gas tank and filler neck, cut that shit out and weld in a new panel. personally I wouldnt even drive it like that, having the strut mounted to a rusty panel is not very safe. Quote Link to comment
Guest 510kamikazifreak Posted September 25, 2009 Report Share Posted September 25, 2009 What Skib says about driving it like that, big risk. I wouldnt put the effort into replacing the inner wheelhouses myself.Big job,In the end is it going to be worth it.(jmo) Glass is going to do nothing for structural integrity what so ever. There is a 86 Pulsar on kijiji in Saskatoon. Quote Link to comment
ratsar_nx Posted September 25, 2009 Author Report Share Posted September 25, 2009 I know it's anything but safe... it's not the full coilover mounting there though. The N12 has a trailing arm rear suspension. The spring meets the body further underneath and it's just the shock that mounts to the body in the location you see in the picture. If the panel did decide to give out, I wouldn't be losing all support on that corner, but it would definitely be a bad thing. Quote Link to comment
Guest 510kamikazifreak Posted September 25, 2009 Report Share Posted September 25, 2009 One good bump and the shock will blow through the wheel house,At any kind of speed it could be catastrophic for you and anyone around you.:eek: Quote Link to comment
ratsar_nx Posted September 25, 2009 Author Report Share Posted September 25, 2009 I missed your first post when I posted my reply, 510freak. The possibility of retiring my beloved N12 is there in my head, as much as I like the car. After all, if I fix the wheel wells, what's going to break next? Depending on the welding patch job, it might not be safe even if I do repair it. I had a look at that '86 Pulsar on Saskatoon kijiji... That guy is asking too much for it, IMO. If it does get replaced, I'm definitely going Japanese, maybe European if I could get a good deal. Ideally, if I do get a replacement, it would be another Nissan or Datsun. Quote Link to comment
Guest 510kamikazifreak Posted September 25, 2009 Report Share Posted September 25, 2009 You could always low ball offer the guy. There must be more pulsars in that area, There are a couple 87-89 body styles for sale in that area for around 1k Quote Link to comment
MikeRL411 Posted September 26, 2009 Report Share Posted September 26, 2009 Get some 3 inch C channel iron, fab a triangulated cage to accept the shocks and then fiberglas or steell is a personal choice. Worked on my 1955 Chevy, don't ask me what year I did it! You were probably not even born then. Yes, I am a "senior" in more ways than one. Quote Link to comment
thisismatt Posted September 26, 2009 Report Share Posted September 26, 2009 Doesn't look like too difficult of a repair job, especially considering it doesn't have to be very pretty. Quote Link to comment
ratsar_nx Posted September 26, 2009 Author Report Share Posted September 26, 2009 It doesn't have to be pretty, but it would have to stand up to snow and salt. I'm pretty sure that's why it rusted out in the first place... snow filled with sand and salt wedged between the shock and the body. Also, there is some rust penetration in the body further down which must have let some moisture in. Quote Link to comment
72240z Posted September 26, 2009 Report Share Posted September 26, 2009 I agree with matt. That's like a lazy afternoon for any capable welder. If you love the car is that really a high price? I don't think so. Quote Link to comment
