Docsis510 Posted September 9, 2009 Report Share Posted September 9, 2009 I'm having issues with the motors mounts on my 510. I did a ka24de swap and the motor is ripping the driver side motor mount right off. I installed 3 mount and all of them got ripped. I'm not Shure if it's right but I'm having to put a spacer between the motor mount and the crossmember because the motor won't make it to the mounts hole. Is there other mounts I can buy that are stronger or mabe different style mounts? Any help or info will be apriciated. Thanks Quote Link to comment
Pacific coast Datsun Posted September 9, 2009 Report Share Posted September 9, 2009 How big is the spacer ? That could be the issue..im wondering why the mounts are'nt linng up. If need be i could make a new motor mount thats longer & eliminate the spacer. Quote Link to comment
compression Posted September 15, 2009 Report Share Posted September 15, 2009 it shouldnt rip it if they are aligned, do you have to tweak the motor mount to get it to bolt up? Was the crossmember modified for a KA? or is it stock? Quote Link to comment
DISLEXICDIME Posted September 15, 2009 Report Share Posted September 15, 2009 show some pics of the mount Quote Link to comment
Pacific coast Datsun Posted September 15, 2009 Report Share Posted September 15, 2009 show some pics of the mount Yeah Jose like i said i can make you what you need & im not sure when i can get over to you. Get a few good close pix with a measuring tape if possible. Quote Link to comment
Docsis510 Posted September 16, 2009 Author Report Share Posted September 16, 2009 thanks for the help guys but i think i finally figuered it out. when i installed the motor mounts i aligned the 4 holes from the crossmember to the four holes on the motor mounts. well i guess that was the wrong way. the right way was that the 2 top holes on the motor mount went into the 2 bottom holes on the crossmember. thats why the motor wouldnt make it from on side to the other and would put tension on one of the motor mounts. i think im ready to drive this sucker!!!!!! Quote Link to comment
fo0manchu Posted September 16, 2009 Report Share Posted September 16, 2009 thanks for the help guys but i think i finally figuered it out. When i installed the motor mounts i aligned the 4 holes from the crossmember to the four holes on the motor mounts. Well i guess that was the wrong way. The right way was that the 2 top holes on the motor mount went into the 2 bottom holes on the crossmember. Thats why the motor wouldnt make it from on side to the other and would put tension on one of the motor mounts. I think im ready to drive this sucker!!!!!! exciting! Quote Link to comment
