g-mam Posted August 8, 2009 Report Share Posted August 8, 2009 Well, not too bad. Got the new Tach in, everything was cool, but the signal indicators were not working for some reason. Found out they just weren't getting a good ground. Then the instruments fell, hit the steering column, and a piece broke off the circuit board. There were two traces there. I Epoxy'd the piece back, dremeled the coating off and soldered the traces back. It works. This is the ony place that the board sticks out past the housings just waiting to be snapped off! Now, I have a question of course :D Under the dash, just right of the ashtray opening, there is a silver box, with a connector. This is disconnected on my truck. Can't figure out what it is. Tomorrow I will try to snap a photo. It's been like that since I got the truck, so I'm afraid to just plug it back in. If you have any gueses what it is, let me know. Quote Link to comment
stevensonDNL Posted August 8, 2009 Report Share Posted August 8, 2009 g-mam: Sounds like you're a fairly handy guy when it comes to fixin stuff. One certainly needs to be on these trucks. I just checked out what the little silver box is to the right of the ash tray opening is for you. I happen to have a hole where my radio should be in my "77 620. It's the "fasten seat belts" warning buzzer that works in conjunction with the light on the top center of the dash pad. When you turn the ignition key to "on", it'll go beep...beep...beep for a few seconds to drive you nuts. Someone probably disconnected it to preserve the last vestige of their sanity. I could actually reach in and grasp mine while it was buzzing, and could feel it vibrating in sync. Good luck, and I too love those plaid disco era pants. Dan Quote Link to comment
datsunaholic Posted August 8, 2009 Report Share Posted August 8, 2009 He has a '74, so it doesn't have a seatbelt warning buzzer. That didn't happen until '76. Quote Link to comment
g-mam Posted August 8, 2009 Author Report Share Posted August 8, 2009 He has a '74, so it doesn't have a seatbelt warning buzzer. That didn't happen until '76. Crap, I was hoping it was that simple. Back to the drawing board :confused: Quote Link to comment
g-mam Posted August 8, 2009 Author Report Share Posted August 8, 2009 Here's the repair on the instrument panel. Strange I have continuity between those traces, but I know I do not have a short. They must be related somehow. I connected it and all is well. When I told my wife I did this, she said hell, you'll MacGyver it somehow :lol: Quote Link to comment
g-mam Posted August 8, 2009 Author Report Share Posted August 8, 2009 Okay, here's the disconnected connector. You can see the part number on the item also. Any ideas? Google search only gives me ASSY-RELAY(TYPE K24) but no description. Here's my instrument panel with the Tach installed. Quote Link to comment
g-mam Posted August 8, 2009 Author Report Share Posted August 8, 2009 From the wire colors it may be the B.C.D.D. Relay, what is that? Quote Link to comment
banzai510(hainz) Posted August 8, 2009 Report Share Posted August 8, 2009 B.C.D.D. Relay, what is that? Its on the carb . the other side of the choke,usually the driver side I forget what it does. I never run stock carbs so I dont care Quote Link to comment
g-mam Posted August 9, 2009 Author Report Share Posted August 9, 2009 Well, got the instrument panel all back together and in the dash, all is working well. Anyone else want to chime in on what that relay does? This thing still chokes and coughs when I first start it up, but when it gets to temp all seems pretty good. Not sure of the cause. Quote Link to comment
stevensonDNL Posted August 10, 2009 Report Share Posted August 10, 2009 Thank you, datsunaholic for correcting me on that not being a seat belt warning buzzer. I stand (actually I'm sitting down) corrected. Dan Quote Link to comment
ramrod Posted December 6, 2012 Report Share Posted December 6, 2012 Old thread, but can you tell me where the +12V for the instrument lamps comes from? mine is disconnected and I don't see any loose wires. Quote Link to comment
datzenmike Posted December 7, 2012 Report Share Posted December 7, 2012 Some early 620 didn't have a dimmer control but '74 and up did. Power flows from the fuse box to the light switch, to the dash lights and from them to the dimmer switch which adjusts the resistance to ground. You may have power to the lamps but to complete the circuit the other side must get to ground. Power for the illumination lamps comes into the dash on the #4 plug wire and is Green/Blue stripe. The ground return to the dimmer is the #2 plug wire and is Green/Black stripe. Quote Link to comment
