datrod Posted August 1, 2009 Report Share Posted August 1, 2009 O.K. my alt went out last weekend so I take the battery and alt down to the parts house. Batt is O.K. but the bearing in the alt was bad. So they sold me a new alt. Now I just drove the car for a few miles. And today car won't start. WTF!!!!! Quote Link to comment
ggzilla Posted August 1, 2009 Report Share Posted August 1, 2009 Bad bearing won't cause charging problem. It just be noisy. Perhaps you left the lights or radio on? Quote Link to comment
datrod Posted August 2, 2009 Author Report Share Posted August 2, 2009 No I didn't leave the lights on. Hell I never drive it at night.:lol: And the radio turns off with the key. Quote Link to comment
datzenmike Posted August 2, 2009 Report Share Posted August 2, 2009 Turn everything off and connect a test light between either battery cable and the battery post.... if it lights up something is drawing power. Unplug the alt and see if it stops.... then pull each fuse till it goes out and this is the circuit with the draw. Could be the external regulator if equipped. Quote Link to comment
datrod Posted August 2, 2009 Author Report Share Posted August 2, 2009 Turn everything off and connect a test light between either battery cable and the battery post.... if it lights up something is drawing power. Unplug the alt and see if it stops.... then pull each fuse till it goes out and this is the circuit with the draw. Could be the external regulator if equipped. There is a large ground wire comming out of the same loom that hooks up to the alt. It was not even touching any metal. So I'm guessing that my alt was not grounded Correct? I took the alt to the auto parts store and it checks out fine. So charge the batt and tighten the ground and I should be on my way. Quote Link to comment
ggzilla Posted August 2, 2009 Report Share Posted August 2, 2009 Maybe. The alternator also grounds through the bracket. The ground wire is just in case. Charge the battery, then start the engine and test the Voltage at battery when running at 1200 RPM. If it is 13.5-15.0 volts all is well. Quote Link to comment
datrod Posted August 2, 2009 Author Report Share Posted August 2, 2009 Thanks guy's. I'm having the parts store charge the batt and I'll go pick it up in a few minutes and see what happens. I think I might buy one of them little gages. So I know how many amps I'm pulling with the stereo and all running. The first thing the kid at the parts store asked me was do you have a system. I'm like NO but I have a stereo in there. :lol: Quote Link to comment
ggzilla Posted August 2, 2009 Report Share Posted August 2, 2009 Forget the ammeter. Get a voltmeter, it's far more useful. Quote Link to comment
datrod Posted August 2, 2009 Author Report Share Posted August 2, 2009 Thanks gzilla. O.K. so i put everything back on the car. It starts but when I disconnect the positive cable it dies. Would that be the regulator that's not letting the alt work. I'm a complete dumb ass when it comes to anything with wires. :( Quote Link to comment
ggzilla Posted August 2, 2009 Report Share Posted August 2, 2009 (edited) You cannot tell what the exact problem is by pulling the cable. That only tells you that something is wrong. You need a voltmeter, ask a friend with one to stop by. * If the voltage is higher than 15.0 volts, the regulator is bad and it's good bet that is has damaged the battery. * If the voltage output is low, hot-wire the alternator and check the voltage again. Directions are here: Datsun Alternator testing Regulator bypass testing Edited August 2, 2009 by ggzilla Quote Link to comment
datrod Posted August 2, 2009 Author Report Share Posted August 2, 2009 Cool thanks. I'll check it in the A.M. Quote Link to comment
Duke Posted August 2, 2009 Report Share Posted August 2, 2009 I'm a complete dumb ass when it comes to anything with wires. :( All I know 'bout them wires is they run on smoke. If you let the smoke out, it don't work no more. Quote Link to comment
datrod Posted August 2, 2009 Author Report Share Posted August 2, 2009 All I know 'bout them wires is they run on smoke. If you let the smoke out, it don't work no more. :lol: Quote Link to comment
datrod Posted August 2, 2009 Author Report Share Posted August 2, 2009 Got it. The regulator was bad. And I also had some bad wires down there so I kinda fixed thm. I need to go back and fix them all soon. Thanks for the help ggzilla & dmike :D Quote Link to comment
ggzilla Posted August 2, 2009 Report Share Posted August 2, 2009 Glad to hear. Another Datsun back on the road! Quote Link to comment
