uhhitsfuzzy Posted July 16, 2009 Report Share Posted July 16, 2009 suggestions on which carbs i should use? the last owner put a crappy carb in the 620. i get alot of backfiring. got pulled over for it today. CHP told me i should get it fixed by tomorrow coz he will be waiting on the exit i usually take to go to my work. sucks!! helpppp! Quote Link to comment
banzai510(hainz) Posted July 16, 2009 Report Share Posted July 16, 2009 if you have a point distributor make sure you got a good condensore in there and time it. maybe adjust the mixture screwat base of carb . the one with the tension spring on there. Quote Link to comment
fastdadd Posted July 16, 2009 Report Share Posted July 16, 2009 that and leave for work 30 min early:lol: Quote Link to comment
1lo620 Posted July 16, 2009 Report Share Posted July 16, 2009 that and leave for work 30 min early:lol: that will fix that CHP...you show him whos boss...:D Quote Link to comment
datzenmike Posted July 16, 2009 Report Share Posted July 16, 2009 Backfiring through the exhaust??? Not necessarily the carb's fault. Could be bad dizzy cap or wires cross firing. Loose ignition wiring to dizzy or coil. Bad exhaust valve? Quote Link to comment
