N0RCALDIME Posted April 20, 2009 Report Share Posted April 20, 2009 so i got a new speedo cable kit. just the cable with the other attatchment peices. how the hell do i set this thing up? i'm sure it being 4/20 doesnt help but i cant figure this out. SOS thanks Quote Link to comment
N0RCALDIME Posted April 21, 2009 Author Report Share Posted April 21, 2009 nobody knows...:confused: Quote Link to comment
sssr20det510 Posted April 21, 2009 Report Share Posted April 21, 2009 Post up pics of what you got Quote Link to comment
datzenmike Posted April 21, 2009 Report Share Posted April 21, 2009 (edited) Is this just a replacement speedo cable assy. for a 510? Stock or for a longer 5spd? Post up pics of what you got yeah I'd hate to find out later that you have a KA24DE and FS5W71C with electronic sensor speedo. Edited April 21, 2009 by datzenmike Quote Link to comment
ggzilla Posted April 21, 2009 Report Share Posted April 21, 2009 speedo cable kit.Meaning what? For a Datsun, I have seen: - Complete new cable about $15 at Rockauto.com - new shaft kit, about $8. It's just the inside part. It must be the correct length and you pull the broken shaft-cable out of the cable sheath, soak the new cable in light motor oil, then put it into the sheath. Quote Link to comment
banzai510(hainz) Posted April 21, 2009 Report Share Posted April 21, 2009 510 speedo cable 4speed.assume it fits a 5speed also B5050-Y8101 thru dealer or nissanparts.cc a generic will work but the square end has to fit in the dash instrument cluster. soem times you have to gently shave them w/o stripping them. what I do is take the old one out and measure ir. use the old KEY in the trans drill it out.JB weld it. then shave the upper part so it fits in the speedo itsself. But for you, just buy the cable. if cable is good its the speedo pinion in the trans that you need. the plastic teeth stripped out(design that way) Quote Link to comment
N0RCALDIME Posted April 21, 2009 Author Report Share Posted April 21, 2009 its just the cable that goes inside the sleeve and the shaft and a metal peice that crimps it on i guess. it was given to me by a local dime owner so i would hope its the right one...? there is no old cable in the sleeve. so i just unscrew the peice from the transmission and insert the new cable and guide it up? ive gotta get some jackstands. damn thing almost killed me. Quote Link to comment
banzai510(hainz) Posted April 21, 2009 Report Share Posted April 21, 2009 Buy the 510 cable from Nissan. You need the Datsun Key that goes in the trans to turn the speedo. Like I said before I use the Datsun Key(goes in the trans and drill it out for the new cable. there is nothing to crimp. Thats why he gave it to you. Its a Common 510 trick. Give something away .The new guy thinks ,"Hey we must be buds" Quote Link to comment
N0RCALDIME Posted April 21, 2009 Author Report Share Posted April 21, 2009 Buy the 510 cable from Nissan. You need the Datsun Key that goes in the trans to turn the speedo. Like I said before I use the Datsun Key(goes in the trans and drill it out for the new cable. there is nothing to crimp. Thats why he gave it to you. Its a Common 510 trick. Give something away .The new guy thinks ,"Hey we must be buds" lol damn 510 tricks. Quote Link to comment
