datsun 521 a/c unit complete 400.00
  • Replies 17
What did he do? I was about to tell you guys how to make that AC system work much better. I guess there'd be no point now. (I'm also an AC tech)
It is an old score Stephen. :mellow:
We had some issues in the past with this guy and let's just say that he is not welcome here anymore. He knows why. ;)
I replace the upright York compressor with either a Sanden or Hitachi rotary compressor. And use the largest condensor you can fit behind your grille. That makes the system run 8-12 degrees cooler than the upright. Most of the parts needed can be found in the junkyard. Things like brackets, pulleys, idlers, etc. You can even add a pusher type fan of the front of the condenser to help with cooling at low speed/idle.
thanks. Rotary like on honduhs right? Coolness park.
I'll actually use the Sanden SD508 because there are universal brackets available for them or the Hitachi MJ167 from a ZX/Maxima because the brackets for them bolt on to an L series. You'll have to have hoses made up for the changeover. I have the equipment to do that but most AC shops can do that also.
