Need a pulley for early generator
  • $20 WANTED
  • Offered by: 22350
  • 4 days and 15 hours left ()
Hello.  I am looking for a pulley.  should be the same on all 64 and earlier 1200's
This is off of a 320 pickup
If you come up empty for an actual Datsun pulley, look for an old school British resto shop in your area (wherever that is), cuz many of the early Datsun parts were basically licensed/copied from British engineering by Datsun.  I worked in the British parts industry for years.  Is that a cast pulley?  I don't remember the British counterpart being cast, but if the same engineering design in stamped steel, one might work......?  There might be a "spacer" behind your pulley (the British DID have a spacer), so if you find a British pulley that fits the shaft but rubs on the generator itself, look into spacing it out with a deeper spacer.  Good luck with your search!
