H165 Rear Diff Pinion Crush Sleeve Spacer + Gasket
  • Ask for price WANTED
  • Offered by: Hondanx250
  • 15 hours and 53 minutes left ()
  • Item Condition NEW
ISO H165 Rear Diff Pinion Crush Sleeve Spacer.
Anyone know a source of Old stock parts? Looking to rebuild Diff with new bearings. So in need of the Crush sleeve Pinion Spacer. Part Number: # 38165-N5000. I know i could probably machine one as per the research i did, thought i'd see what out there first.
Thanks
Looking for the following Items.
1x Spacer Pinion Bearing # 38165-N5000
1x Gear Carrier Gasket # 38320-N5001
I'd like to have one also so I'll be watching this. I can say that it's 48.4mm long, correct? Do you have other dimensions?
Did you try Nissan dealer??
I doubt you'll find a gasket, they're discontinued. Just use a good quality sealer like Permatex Blue... https://www.permatex.com/products/gasketing/gasket-makers/permatex-gear-oil-rtv-gasket-maker/
81182.jpg?lossy=1&strip=1&webp=1
Hondanx250
Found a Company over in Japan that said they found some and ordered em, We will see.
Other adverts from Hondanx250
