rusty510 Posted February 24, 2009 Report Share Posted February 24, 2009 1- i have noticed that the L series uses the same oil filter as some ford v8s, does this mean that i could use a "sandwich" adapter for a ford v8 to get an oil feed? or do any of you know where to get one for an L series? 2- i read in another thread that the oil pumps from ka motors will work on an L series and provide more oil flow, is this a direct bolt in or what modifications does it take to work? thanks in advance for any help. Quote Link to comment
Bleach Posted February 24, 2009 Report Share Posted February 24, 2009 1. Probably not Ford. You can find a factory oil cooler kit from the 1981-83 280ZX turbo, but only the turbo engine with an automatic transmission had them. otherwise, Summit racing (.com) has a couple L-series sandwich options. 2. Yes, they bolt in and had more oil volume and slightly higher pressure. The same oil pump was used on the L28et. 280zx turbo and KA24 were the same oil pumps. :) Quote Link to comment
pl521sss Posted February 24, 2009 Report Share Posted February 24, 2009 1. Probably not Ford. You can find a factory oil cooler kit from the 1981-83 280ZX turbo, but only the turbo engine with an automatic transmission had them.otherwise, Summit racing (.com) has a couple L-series sandwich options. 2. Yes, they bolt in and had more oil volume and slightly higher pressure. The same oil pump was used on the L28et. 280zx turbo and KA24 were the same oil pumps. :) speaking of oil pumps I have a 280zx Turbo oil pump mixed in with the regular oil pump parts bin Are they stamped with a number that tells me it's a turbo oil pump? Quote Link to comment
Skib Posted February 24, 2009 Report Share Posted February 24, 2009 there is a ford oil filter that fits the L6, its the same thread and diameter. Its usefull b/c the L6 ones kinda short and stubby and the ford one is "taller". ill try and find the P/N Quote Link to comment
datzenmike Posted February 24, 2009 Report Share Posted February 24, 2009 (edited) speaking of oil pumpsI have a 280zx Turbo oil pump mixed in with the regular oil pump parts bin Are they stamped with a number that tells me it's a turbo oil pump? They are indistinguishable from the outside when mounted. Here is a regular oil pump. The horizontal surface down inside the oil inlet port is the top of the rotor. http://i138.photobucket.com/albums/q251/datzenmike/motorHi-volumeoilpump1Lg.jpg[/img]"] Here is a hi vol pump. You can clearly see that the rotor is much taller and fills part of the inlet port. http://i138.photobucket.com/albums/q251/datzenmike/motorHi-volumeoilpump2Lg.jpg[/img]"] They were used on both the automatic and standard L28ET motors. The part numbers for the standard does not match the automatic but does match the '86.5-88 D21 Hardbody with Z24i motor. The KA24E used in the '88 and up Hardbody and the 240sx car were different part numbers also but were still the hi vol pump. In fact any E or DE KA motor used in a RWD vehicle should have it. The different numbers were likely different pressure release spring rates for different motors. The hi vol pump was also used on the '81-'83 Maxima with the LD28 Diesel option, and was rumored to have been used in the JDM Z18ET motor. May* have been used on propane powered L20B lift truck motors. A higher vol pump will still put out roughly the same pressure as the old one as it is dependent on the relief spring pressure. However at low pump speeds it supplies more oil to leaky bearing surfaces and will raise the pressure. I went from 17 to 29 lbs hot idle oil pressure. Very comforting. Edited February 25, 2009 by datzenmike 1 Quote Link to comment
pl521sss Posted February 25, 2009 Report Share Posted February 25, 2009 1. Probably not Ford. You can find a factory oil cooler kit from the 1981-83 280ZX turbo, but only the turbo engine with an automatic transmission had them.otherwise, Summit racing (.com) has a couple L-series sandwich options. 2. Yes, they bolt in and had more oil volume and slightly higher pressure. The same oil pump was used on the L28et. 280zx turbo and KA24 were the same oil pumps. :) They are indistinguishable from the outside when mounted. Here is a regular oil pump. The horizontal surface down inside the oil inlet port is the top of the rotor. Here is a hi vol pump. You can clearly see that the rotor is much taller and fills part of the inlet port. Thanks Mike Quote Link to comment
Skib Posted February 25, 2009 Report Share Posted February 25, 2009 the threads on a Ford 302 are 3/4" 16 tpi (NF). This is the same size as what I use on both the Ford and Datsun. Quote Link to comment
datzenmike Posted February 25, 2009 Report Share Posted February 25, 2009 All North Am block threads are the same, at least back then. There were 2-3 different gasket placement spin-ons to choose from but hard to use the wrong one. I have used the 300 cu in inline Ford six, GM 305 V8 and Chrysler 318. All fit, were larger and best... cheaper. I would just look up the L20B filter and compare to the larger ones and make sure the rubber gasket is in the same place. I use the cheapo Canadian Tire ones made by Fram. Get changed twice a year so only couple of thousand miles anyway. Hey reality check, it's only 80-90 (maybe) hp anyway and they have worked good. Quote Link to comment
rusty510 Posted February 26, 2009 Author Report Share Posted February 26, 2009 great thanks for the help! found the adapters on summit, and i am going to get the pump for an 89 240sx as it is $25 cheaper than the hardbody one. Quote Link to comment
datzenmike Posted February 26, 2009 Report Share Posted February 26, 2009 (edited) Because they look the same memorize those pictures and don't let them sell you the wrong one. Some kid might have had them out and got them in the wrong boxes. I'll bet there's more than one person out there that thinks they have a hi vol pump that doesn't. http://i138.photobucket.com/albums/q251/datzenmike/IMG_0195.jpg[/img]"] Not the best picture but you can see the difference in length of the rotors. The hi vol rotors are 1.5625" long standard are 1.375" that's about 14% longer... makes a BIG difference. Edited February 26, 2009 by datzenmike Quote Link to comment
