izzo Posted February 23, 2009 Report Share Posted February 23, 2009 (edited) Looking for the following parts Lock/key tumble and matching door locks with keys (i will settle for door locks with a key!) Weber 32/36 carb smog exempt intake, idc if you just welded one up as long as all that shits gone off it. Hell, if you're somewhat local to Seaside & have a welder maybe you wouldnt mind closing it up for me, or for? Would like an peanut head, but will take less desirable one as long as everthings in good shape, no blowby etc... Might be more, ill add later if so. I would like a weber, however stock might have to do depending on prices. I am on a tight budget, so let me know what you got and how much and see if we can work somethin out. Thanks in advance Edited February 23, 2009 by h2theizzo Link to comment
bagged_datsun Posted February 23, 2009 Report Share Posted February 23, 2009 i have a good head, opened chambered tho Link to comment
izzo Posted February 23, 2009 Author Report Share Posted February 23, 2009 thats fine mine has some blow by, i don't think its to serious as i dont see a lot of oil slung everywhere just like a mist or something. going to check the clearance next weekend but its probably just due for a rebuild. pm me and let me know what your asking, thank you!! Link to comment
izzo Posted February 23, 2009 Author Report Share Posted February 23, 2009 (edited) Need a wiper motor too. Edit -- Need bench or bucket seat too Edited February 24, 2009 by h2theizzo more to add Link to comment
izzo Posted February 26, 2009 Author Report Share Posted February 26, 2009 Bump Anyone have a webber they want to sell? Need doors and hinges for my 720 still if anyone has them Possibly still need a head, will know after this weekend. Link to comment
izzo Posted February 27, 2009 Author Report Share Posted February 27, 2009 Got the following so far, head/intake/exhaust/weber Still need doors, cmon someone has to have a set :D Looking for a block now, so i can keep driving my truck and just build one then throw it in on a weekend so i dont have any down time Lookin for block that still has pan/crank/pistons/front timing cover etc.. Let me know what you have ill figure something out soon, i went outside and looked around and look what i saw! oil puddle on the lip. somethings leaking and i need to get it done soon its my daily driver Link to comment
izzo Posted March 2, 2009 Author Report Share Posted March 2, 2009 bump Still need a weber 32/36 Link to comment
datto510 Posted March 2, 2009 Report Share Posted March 2, 2009 i went outside and looked around and look what i saw! oil puddle on the lip. somethings leaking and i need to get it done soon its my daily driver Check the base of your distributor and valve cover. When you gonna swap out the heads? Link to comment
banzai510(hainz) Posted March 2, 2009 Report Share Posted March 2, 2009 I think that a normal oil leak on old datsuns. Redon the front cover gasket and up in the corners and put a new front crank seal. That should take care most of it. http://www.guba.com/general/search?query=hainz&set=5&x=17&y=10 Link to comment
izzo Posted March 3, 2009 Author Report Share Posted March 3, 2009 Check the base of your distributor and valve cover. When you gonna swap out the heads? Not this weekend, but the next, want to join in? :D Still need Weber Still need wiper motor Thanks Hainz, i have your video bookmarked already and ill be using it when i do this stuff, unless datto510 has time to be a mentor lol! I am going to order timing gasket kit, already have valve cover gasket, getting a oil pan one also. ill check rock auto for the crank seal Hainz, do you know what head gasket to use on rock auto? I saw 2 options and wasnt sure what the better was or the one you recommended in the video Link to comment
izzo Posted March 4, 2009 Author Report Share Posted March 4, 2009 Have Weber Still need Windshield wiper motor ------ Link to comment
izzo Posted March 6, 2009 Author Report Share Posted March 6, 2009 Still need wiper motor BUT!!!!!!!!!!!! More important. I am in desperate need of a windshield!!!!!!!!!!!!!!!!!!!!!!!!1 It was already cracked and someone kicked a rock on the window doin about 70 on highway 26, that shit busted more and the wind from driving is strong enough to make it keep cracking. I can see it happen when i drive. Anyone???? Link to comment
Suspect Posted March 13, 2009 Report Share Posted March 13, 2009 I have a wiper motor...... Link to comment
izzo Posted March 13, 2009 Author Report Share Posted March 13, 2009 Right on! Are the 620 & 720 wiper motors the same? Pm me and let me know a price and what you will charge for shipping to 97138 Thank you! Link to comment
izzo Posted March 13, 2009 Author Report Share Posted March 13, 2009 (edited) Couple more things i could use 720 carpet Transmission hump metal cover, have a floor mat covering the hole right now Could still use some door locks or doors preferred Need Hinges. Edited March 13, 2009 by h2theizzo more stuff to add Link to comment
izzo Posted March 18, 2009 Author Report Share Posted March 18, 2009 ........... Bump 720 carpet Transmission hump metal cover, have a floor mat covering the hole right now Could still use some door locks or doors preferred Need Hinges. Wiper motor Link to comment
BarryA Posted March 24, 2009 Report Share Posted March 24, 2009 Are the 620 & 720 wiper motors the same? interchange - in the process of setting up the 720 turn signal / headlight / wiper stalk switch assembly on the 79 620 KC, I pulled an early 720 wiper motor and compared it to a late 620 motor - mounting points on the 720 unit didn't align with the holes in the 620 cowl, motor was oriented differently, and if I remember correctly, the drive arms didn't interchange either............ Link to comment
izzo Posted March 24, 2009 Author Report Share Posted March 24, 2009 interchange - in the process of setting up the 720 turn signal / headlight / wiper stalk switch assembly on the 79 620 KC, I pulled an early 720 wiper motor and compared it to a late 620 motor - mounting points on the 720 unit didn't align with the holes in the 620 cowl, motor was oriented differently, and if I remember correctly, the drive arms didn't interchange either............ Didn't think they were, thanks for that info! Bump, i still need those parts and some others Link to comment
Scuba002 Posted March 26, 2009 Report Share Posted March 26, 2009 I have a power door lock key w/ 2 transmitters I'll sell ya for $50 and if any of the 78 620 lock componets will fit then let me know. Link to comment
izzo Posted March 26, 2009 Author Report Share Posted March 26, 2009 ill keep that in mind dood, doesnt sound to bad. I have never done a power door lock install but might be fun :D Cant afford the 50 right now sorry, ill keep that on the back burner and ask if i can come up with it. BUMP! 720 carpet Transmission hump metal cover, have a floor mat covering the hole right now Could still use some door locks or doors preferred Need Hinges. Wiper motor Also need, One stock 1980 720 lug nut. Ill take a pic and show what it looks like if needed. I am missing one and ordered a new stud for it Link to comment
izzo Posted April 3, 2009 Author Report Share Posted April 3, 2009 BUMP! Someone has to have a 68 valve cover i can buy from them. I had a chance to get one from rubberman but was a minute to late for 20 bux, good shape too Someone!!!!!! Hook me up! Need these parts too 720 carpet Transmission hump metal cover, have a floor mat covering the hole right now Could still use some door locks or doors preferred Need Hinges. Wiper motor D21 spindles & calipers Need a rear end, stock 1980 4 sp whatever came with that is what i have now and its to high of RPM for 60mph Link to comment
izzo Posted April 7, 2009 Author Report Share Posted April 7, 2009 BUMP!!!!!!!1 Need these parts too 720 carpet Transmission hump metal cover, have a floor mat covering the hole right now Could still use some door locks or doors preferred Need Hinges. Wiper motor D21 spindles & calipers Need a rear end for my 720, 3.8? or 3.7? Link to comment
Zombro Posted April 26, 2009 Report Share Posted April 26, 2009 May be able to help you out. check the project datto thread to see the 720. Link to comment
