720 & L20 parts
izzo
Looking for the following parts
Lock/key tumble and matching door locks with keys (i will settle for door locks with a key!)
Weber 32/36 carb
smog exempt intake, idc if you just welded one up as long as all that shits gone off it. Hell, if you're somewhat local to Seaside & have a welder maybe you wouldnt mind closing it up for me, or for?
Would like an peanut head, but will take less desirable one as long as everthings in good shape, no blowby etc...
Might be more, ill add later if so.
I would like a weber, however stock might have to do depending on prices. I am on a tight budget, so let me know what you got and how much and see if we can work somethin out.
Thanks in advance
Edited by h2theizzo
  • Replies 23
thats fine
mine has some blow by, i don't think its to serious as i dont see a lot of oil slung everywhere just like a mist or something. going to check the clearance next weekend but its probably just due for a rebuild.
pm me and let me know what your asking, thank you!!
Got the following so far, head/intake/exhaust/weber
Still need doors, cmon someone has to have a set :D
Looking for a block now, so i can keep driving my truck and just build one then throw it in on a weekend so i dont have any down time
Lookin for block that still has pan/crank/pistons/front timing cover etc..
Let me know what you have ill figure something out soon, i went outside and looked around and look what i saw!
oil puddle on the lip. somethings leaking and i need to get it done soon its my daily driver
Check the base of your distributor and valve cover. When you gonna swap out the heads?
Not this weekend, but the next, want to join in? :D
Still need Weber
Still need wiper motor
Thanks Hainz, i have your video bookmarked already and ill be using it when i do this stuff, unless datto510 has time to be a mentor lol!
I am going to order timing gasket kit, already have valve cover gasket, getting a oil pan one also. ill check rock auto for the crank seal
Hainz, do you know what head gasket to use on rock auto? I saw 2 options and wasnt sure what the better was or the one you recommended in the video
BUT!!!!!!!!!!!! More important. I am in desperate need of a windshield!!!!!!!!!!!!!!!!!!!!!!!!1 It was already cracked and someone kicked a rock on the window doin about 70 on highway 26, that shit busted more and the wind from driving is strong enough to make it keep cracking. I can see it happen when i drive. Anyone????
Couple more things i could use
720 carpet
Transmission hump metal cover, have a floor mat covering the hole right now
Could still use some door locks or doors preferred
Need Hinges.
Edited by h2theizzo
more stuff to add
Are the 620 & 720 wiper motors the same?
interchange - in the process of setting up the 720 turn signal / headlight / wiper stalk switch assembly on the 79 620 KC, I pulled an early 720 wiper motor and compared it to a late 620 motor - mounting points on the 720 unit didn't align with the holes in the 620 cowl, motor was oriented differently, and if I remember correctly, the drive arms didn't interchange either............
Didn't think they were, thanks for that info!
Bump, i still need those parts and some others
ill keep that in mind dood, doesnt sound to bad. I have never done a power door lock install but might be fun :D
Cant afford the 50 right now sorry, ill keep that on the back burner and ask if i can come up with it.
BUMP!
720 carpet
Need Hinges.
Wiper motor
Also need,
One stock 1980 720 lug nut. Ill take a pic and show what it looks like if needed. I am missing one and ordered a new stud for it
BUMP!
Someone has to have a 68 valve cover i can buy from them.
I had a chance to get one from rubberman but was a minute to late for 20 bux, good shape too
Someone!!!!!! Hook me up!
Need these parts too
720 carpet
Need Hinges.
Wiper motor
D21 spindles & calipers
Need a rear end, stock 1980 4 sp whatever came with that is what i have now and its to high of RPM for 60mph
BUMP!!!!!!!1
720 carpet
Need Hinges.
Wiper motor
Need a rear end for my 720, 3.8? or 3.7?
  • 3 weeks later...
