Farmer Joe Posted February 24, 2009 Report Share Posted February 24, 2009 well i guess since youve already had the motor out and back in again, that its not the bellhousing bolts that are loose. i was gonna buy a 620 that did the same thing. it would gring when you hit a bump or kept it at a nuetral rolling force. it would grind if you made a hard turn also. turned out there was only on loose bolt holding the engine and tranny together. and then there were only 4 bolts holding the 6bolt flywheel on. Quote Link to comment
datto510 Posted February 24, 2009 Author Report Share Posted February 24, 2009 I think its gotta be that collar... thew throwout bearing should absolutely NOT be wearing a groove in the clutch diaphram I think your right Joe, I just gotta get the motivation up to pull it again. Next time it comes out its getting a new dogleg. Quote Link to comment
datto510 Posted April 27, 2009 Author Report Share Posted April 27, 2009 Just to update my thread......... I put spacers underneath the carrier bearing anf the noise stopped. I pulled the engine twice before I tried the spacers. :blink: DURH!! Quote Link to comment
ariascarlos1990 Posted April 27, 2009 Report Share Posted April 27, 2009 So the carrier bearing was your problem? with the noise I mean.... Quote Link to comment
datto510 Posted April 27, 2009 Author Report Share Posted April 27, 2009 So the carrier bearing was your problem? with the noise I mean.... Yep. Fixed it right up. Reading your thread about the mystery noise made me think to update mine. Quote Link to comment
lynchfourtwenty Posted April 29, 2009 Report Share Posted April 29, 2009 i have to run a washer on each bolt between tranny and starter cause my flywheel rubs the starter.. not the teeth or nothin but the piece that goes around the gear there.. was pissin me off i tried 3 different starters before i realized what was happening.. havent had problems since.. Quote Link to comment
lynchfourtwenty Posted April 29, 2009 Report Share Posted April 29, 2009 Yep. Fixed it right up. Reading your thread about the mystery noise made me think to update mine. ok ao rhw carrier bearing was the sound.. but whats with the metal shavings? Quote Link to comment
ariascarlos1990 Posted April 29, 2009 Report Share Posted April 29, 2009 Yep. Fixed it right up. Reading your thread about the mystery noise made me think to update mine. I never made a thread about the mystery noise...:confused: Quote Link to comment
lynchfourtwenty Posted April 29, 2009 Report Share Posted April 29, 2009 I never made a thread about the mystery noise...:confused: he must be smokin the good shit.. i want some :( Quote Link to comment
lynchfourtwenty Posted June 12, 2009 Report Share Posted June 12, 2009 so u put some spacers under the CB ?? and the damn vibration went away????? my trucks doin this same crap.. but i have been thinking its u-joints.. hmm?? Quote Link to comment
datto510 Posted June 12, 2009 Author Report Share Posted June 12, 2009 so u put some spacers under the CB ?? and the damn vibration went away????? my trucks doin this same crap.. but i have been thinking its u-joints.. hmm?? Get a 1.5 inch block of aluminum, drill 2 holes in it and put it between the crossmember and the carrier bearing. Your going to need longer bolts too. Be warned, those bolts are a bitch to get in there. Quote Link to comment
lynchfourtwenty Posted June 12, 2009 Report Share Posted June 12, 2009 oh i just fixed my CB, i know :) Quote Link to comment
datto510 Posted June 12, 2009 Author Report Share Posted June 12, 2009 oh i just fixed my CB, i know :) After you put in the spacer there will be even less room to work! I actuall dented my tranny tunnel out a little bit with a hammer to get the bolts in. Quote Link to comment
Wharf Rat Posted June 12, 2009 Report Share Posted June 12, 2009 Just catching up a bit ..... that must have drove you nucking futs :( While reading through I was thinking of loose big truck tranys that do a rattle inbetween load then maybe a exaust or engine contact just barely touching, in the end ..... out of the ooze thats left in my head ..... oh yea my old truck did that trick when the rubber rotted out in the CB:blink: Glad you got it fixed man and everone's still alive even your pets ...... right?:eek: Quote Link to comment
