dat620 Posted February 19, 2009 Report Share Posted February 19, 2009 u go bro, if need be i will get u the other radiator, just don't over do yourself, your health is more important..:) and your welcome, just payin it forward..:) GOD bless u and yours..:) Link to comment
]2eDeYe Posted February 19, 2009 Report Share Posted February 19, 2009 The core supports are different. The newer ones (post L20) are clearanced to fit the bigger rad. I just changed my rad in the '73 too. I had to drill two new holes in the mounting flange, not a big deal. I had to get the upper hose for an L20 engine and trim 3/4" of each end and had to shorten the lower hose too a bit. It is a pretty tight fit around the alternator pully. There isn't much clearance. It seems like the lower inlet is closer to the center than the stock L16 rad. I bet that when I do the SloDat Saturn Alt swap it's going to be a problem. We will see. Really nice to have the new bigger rad though. http://forum.ratsun.net/showpost.php?p=122255&postcount=6 from this thread http://forum.ratsun.net/showthread.php?t=9185&highlight=core+support Link to comment
