SRSANDS Posted February 1, 2009 Report Share Posted February 1, 2009 Does anybody have a schematic for a datsun 510 to completly rewire a new circuit. Im using h4 bulbs and need to completley rewire th system for higher wattage, from the switch to a new relay. Thanks Quote Link to comment
Lozer Posted February 1, 2009 Report Share Posted February 1, 2009 http://www.datsun510.com/modules.php?name=Online_Manuals&file=haynespage&id=181 create an account to view this page. Quote Link to comment
banzai510(hainz) Posted February 1, 2009 Report Share Posted February 1, 2009 (edited) just use the stock wiring harness,this will be your trigger or lowcurrent circut) to trigger a H4 HARNESS as what I did. it plugs right in and took me about 15min to install http://www.4crawler.com/4x4/CheapTricks/Headlights.shtml#OnLineOrdering Edited February 1, 2009 by banzai510(hainz) Quote Link to comment
SRSANDS Posted February 2, 2009 Author Report Share Posted February 2, 2009 Thanks Guys, Hainz, Jeff said if I used a 85 watt bulb upgrade in the ellipsoids my harness will melt and my dash will smoke :) I also plan on changing my lows to a H4 setup in the future.... Quote Link to comment
banzai510(hainz) Posted February 2, 2009 Report Share Posted February 2, 2009 (edited) ellipsoids?????????? I dont know what that is If your going to use H4 outer lamps ,you still can use the H4 harness(thicker wire. and stock wiring as a trigger. The stock high beam comnnector you can use as a trigger also. and another harness or whatever if that is a higher watt circut wire the power to the starter lug. I dont know if your understanding what Iam saying but your just use the stock wiring to tell the New harness w/relays to turn on/off. Ithese 85 watt what ever they are ELLIPSOIDS I assume will have a wire harness of somesort with it or you make it. Here is Cibiews new one http://www.danielsternlighting.com/products/csr.html but uses a H1 bulb (the 2 connector kind) so not to confuse anybody more about hooking this on up!!!!!!! OK Im done Edited February 2, 2009 by banzai510(hainz) Quote Link to comment
