jefe de jefes Posted January 31, 2009 Report Share Posted January 31, 2009 would it fit a 510? It's out of a 1992 subaru svx. Viscous 3.545 gear ratio Part no. 27011aa242 Quote Link to comment
slodat Posted January 31, 2009 Report Share Posted January 31, 2009 The latest Dime Quarterly has an article on what is involved with installing a VLSD in a 510. Quote Link to comment
jefe de jefes Posted January 31, 2009 Author Report Share Posted January 31, 2009 (edited) I'll look into than. Thanks anyone know what they are worth? I have access to one but don't want to get burned. Edited January 31, 2009 by jefe de jefes Quote Link to comment
69FJWagon Posted January 31, 2009 Report Share Posted January 31, 2009 would it fit a 510?It's out of a 1992 subaru svx. Viscous 3.545 gear ratio Part no. 27011aa242 IMO... dont waste you time the brake away on that rear end is nothing and depending on your suspension set up you will find yourself spinning the inside tire more than a clutch type lsd and they tend to be less predictible. I almost wrecked my friend Mikes 240sx because of its unpredictiblity using the VLSD..one minute your sideways the next your spinning the inside tire only not fun :eek: when it happens mid corner Clayton Quote Link to comment
jefe de jefes Posted January 31, 2009 Author Report Share Posted January 31, 2009 So clutch type is better? Quote Link to comment
slodat Posted January 31, 2009 Report Share Posted January 31, 2009 So clutch type is better? much better Quote Link to comment
jefe de jefes Posted January 31, 2009 Author Report Share Posted January 31, 2009 I'll hold off. Thanks Quote Link to comment
slodat Posted January 31, 2009 Report Share Posted January 31, 2009 I doubt you will regret holding out for a clutch type. One sold on ebay recently for about $350.. Quote Link to comment
qwik510 Posted January 31, 2009 Report Share Posted January 31, 2009 IMO... dont waste you time the brake away on that rear end is nothing and depending on your suspension set up you will find yourself spinning the inside tire more than a clutch type lsd and they tend to be less predictible. I almost wrecked my friend Mikes 240sx because of its unpredictiblity using the VLSD..one minute your sideways the next your spinning the inside tire only not fun :eek: when it happens mid corner Clayton I have an Infiniti Q45 R200 VLSD in my LS1 Powered 240Z. I have done many track days and thousands of miles of spririted driving in the car and I have been very happy with the performance of the rear. It has never been unpredictable. I had a Nismo R180 LSD in the car before that with the mildly built L28 engine and I really don't feel that the VLSD is much different. I have had a R160 Subie LSD in a 510 and I just got a Subie VLSD that I may install in my VG30 project. Unless you building a car for all out racing or autocrossing, a VSLD diff should be fine. Quote Link to comment
69FJWagon Posted January 31, 2009 Report Share Posted January 31, 2009 I have an Infiniti Q45 R200 VLSD in my LS1 Powered 240Z. I have done many track days and thousands of miles of spririted driving in the car and I have been very happy with the performance of the rear. It has never been unpredictable. I had a Nismo R180 LSD in the car before that with the mildly built L28 engine and I really don't feel that the VLSD is much different. I have had a R160 Subie LSD in a 510 and I just got a Subie VLSD that I may install in my VG30 project. Unless you building a car for all out racing or autocrossing, a VSLD diff should be fine. David like I said depending on suspension set up it can be better or worse every VLSD I have driven with anything more than a good street tire it felt like a worn out clutch type LSD with the inside tire spinning during hard cornering even my buddys 240sx set up for autocross/drift would spin the inside tire during hard driving and trust me the thing would induce oversteer under initial turn in before adding power because of the set up (more towards drift set up) then during mid corner where power oversteer would be important in drifting the car would slightly unload the inside rear tire turing your oversteer into a quick adjustment to your steering input so not to run into something on the outside of the corner. if you are tracking your car you have obviously spent time to set up your car and with an LS1 (Mmm :cool: great engine) you have more than enough power to turn your tires into liquid rubber. its just my opinion and my experiances with that type of rear diffs...dont get me wrong I would love to see how good your VLSD works in a LS1 Z car :lol::D Clayton Quote Link to comment
Bleach Posted February 1, 2009 Report Share Posted February 1, 2009 I doubt even a well built L20b is going to be breaking tires loose with a 3.54 anyway Quote Link to comment
koback68 Posted February 1, 2009 Report Share Posted February 1, 2009 done that been there on a 510 just get the early suby lsd with the vlsd you will need the stub axles out off the car they came from and machine work to make the diff work right ask ice or frank i repeat do not do it Quote Link to comment
banzai510(hainz) Posted February 1, 2009 Report Share Posted February 1, 2009 (edited) 3.54 is a lame gear ratio stub axles need to be modded. you can still find the3 diffs for cheap if you look HARD enough Dave has found 2 in the last year for under 100$ each and they are the 3.7 ype and just use the 510 stub flanges. Edited February 2, 2009 by banzai510(hainz) Quote Link to comment
koback68 Posted February 2, 2009 Report Share Posted February 2, 2009 hainz its 3 but whos counting but like i said go lsd some people just plug 510 stubs in a vlsd but thats doing nothing you will need the other stubs and machine work.with the lsd plug and play (Dave) Quote Link to comment
Enjride Posted February 6, 2009 Report Share Posted February 6, 2009 I am really happy to read this thread, I almost bought a vlsd 3.54 today until I read this. That would have sucked!!! Quote Link to comment
