Thomas Perkins Posted September 7 Author Report Share Posted September 7 (edited) That film I put over the brake master cylinder with rubber band does good.Not all of the fluid went out.I only had to pump the brakes 5 times then hold,then all air came out.Did it again and no more air came out.Did it again just to make sure.I used my one man bleeder kit,and wife pumped the brake.One time did it.I put some brake fluid in the other wheel cylinder to see if it will release the piston. Edited September 7 by Thomas Perkins Quote Link to comment
Sephakrid Posted September 8 Report Share Posted September 8 I've got those O'Reilly wheel cylinders. Installed sometime in January and put about 1K miles on them so far. I haven't noticed any leaks yet! 1 Quote Link to comment
Thomas Perkins Posted September 13 Author Report Share Posted September 13 (edited) I got my new replacement wheel cylinder today.The guy that put the order in was trying to charge me freight.This one is good,pistons both work.I went to the Nissan dealer and picked up a couple of brake secondary brake clips,just 4 bucks,they had this Nissan Z In the the show room with a stick shift.52,700 bucks,I would get the Nismo.They had 2 GTR's in there a time ago.Check this out.For a extra key,you have to pay 595 bucks.It says,you put 36 grand down and your payments will be 304 a month for 72 months. Edited September 13 by Thomas Perkins Quote Link to comment
Thomas Perkins Posted Friday at 04:35 PM Author Report Share Posted Friday at 04:35 PM The passenger side brake drum does not have the two threaded holes for the 8 mm bolt to screw in to push drum out.Has any one ever drilled cast iron and what drill bits to use and oil. Quote Link to comment
Ooph! Posted Friday at 05:02 PM Report Share Posted Friday at 05:02 PM Regular bits will work, go slow and use oil any type will work if you don't have cutting oil. Quote Link to comment
Thomas Perkins Posted Friday at 05:14 PM Author Report Share Posted Friday at 05:14 PM 10 minutes ago, Ooph! said: Regular bits will work, go slow and use oil any type will work if you don't have cutting oil. Yep I just drilled a pilot bit thru it fixing to do the other one.Went thru it easy. Quote Link to comment
Thomas Perkins Posted Friday at 05:22 PM Author Report Share Posted Friday at 05:22 PM (edited) Other side is done. Edited Friday at 05:23 PM by Thomas Perkins Quote Link to comment
Thomas Perkins Posted Friday at 06:27 PM Author Report Share Posted Friday at 06:27 PM Got one done. Quote Link to comment
Thomas Perkins Posted Friday at 06:48 PM Author Report Share Posted Friday at 06:48 PM Quote Link to comment
Thomas Perkins Posted Friday at 06:57 PM Author Report Share Posted Friday at 06:57 PM I screwed in the screw a little bit then went to drill other hole and hub moved,so it came off.Kewl.I can now take the hub to my table and finished drilling and tapping. Quote Link to comment
Thomas Perkins Posted Friday at 07:01 PM Author Report Share Posted Friday at 07:01 PM Quote Link to comment
Thomas Perkins Posted Tuesday at 09:58 PM Author Report Share Posted Tuesday at 09:58 PM With my new rear wheel cylinders and new brake shoes,my brakes are Awesome.The e brake cable only clicks about 4 to 5 times.Best to change the wheel cylinders everytime you change the brake shoes,less than 20 bucks. 1 Quote Link to comment
