Larsonian Posted July 29 Report Share Posted July 29 Im in the middle of swapping out my auto trans for a 5speed in my 1980 510. I'm wondering what bolts I would need to connect the bell housing to the engine. Could I use the transmission bolts from a ca18? or sr20? or do I just need to find each bolt's pitch and length? Quote Link to comment
datzenmike Posted July 29 Report Share Posted July 29 I imagine the CA/SR bolts are the same thread. Length would be the important thing. The top two holes are blind so you don't want bolts that are too long or they'll tighten but not be up against the transmission. Too short and there's not enough thread engagement. You should have 1.5 X the bolt width of threads engaged into the block. Quote Link to comment
Stoffregen Motorsports Posted July 30 Report Share Posted July 30 10x1.5 thread, right? 1 Quote Link to comment
Larsonian Posted July 31 Author Report Share Posted July 31 On 7/29/2024 at 1:20 PM, datzenmike said: I imagine the CA/SR bolts are the same thread. Length would be the important thing. The top two holes are blind so you don't want bolts that are too long or they'll tighten but not be up against the transmission. Too short and there's not enough thread engagement. You should have 1.5 X the bolt width of threads engaged into the block. how can i make sure they're the right length? Quote Link to comment
Stoffregen Motorsports Posted July 31 Report Share Posted July 31 Well they obviously should not bottom out and they need to engage by at least five or ten threads. Quote Link to comment
iceman510 Posted July 31 Report Share Posted July 31 2 hours ago, Larsonian said: how can i make sure they're the right length? Depth of the bolt hole plus the flange thickness of the joining part, minus some clearance margin. And keeping in the guidelines of thread engagement mentioned by the two guys above. Keep it between those max/min dimensions. 1 Quote Link to comment
Larsonian Posted August 3 Author Report Share Posted August 3 On 7/31/2024 at 3:53 PM, iceman510 said: Depth of the bolt hole plus the flange thickness of the joining part, minus some clearance margin. And keeping in the guidelines of thread engagement mentioned by the two guys above. Keep it between those max/min dimensions. alright thank you ill figure it out Quote Link to comment
