PercyTheAce Posted July 15 Report Share Posted July 15 So I’ve had this issue happen at least 3-4 times now in the last 4ish months. The front alternator bolt that the alternator hinges on keeps snapping off and I can’t figure out why. It shears off flush with the mounting bracket, and I’ve tried replacing it with a shouldered bolt that’s stronger than the original bolt, I’ve even tried a bolt that matches the original bolts hardness. And yes I’ve double checked the torque spec, it’s only around 5 ft-lbs which is what I’m tightening to. I’ve even swapped to a different bottom mounting bracket. The only other thing I can think of that it might be is the alternator casting is bad causing it to be misaligned, but I’d been running that alternator for about 4 months prior to having any issues. Anyone have any ideas? Quote Link to comment
banzai510(hainz) Posted July 15 Report Share Posted July 15 (edited) Is your 210 lowered down almost to the bumpstops? My 510 did this all the time.when I had the smaller bolts in there. usually the frontbolt.car was slammed in front and bumpy roads to work.Always fixing it!!!!!!!!!!!!!!!Allways!!!!!!!!!!My life was better when I really had the proplem fixed. I found a spare 510Alternator mounts(lots of them) and had a machine shop drill it out. I think 3/8s bolt. You can use a nut on the end or what I did on one is drilled out the back ear of the alt and put a keensert so Idint no have to use a nut.But remeber the stores like Napa might take them back as a core for rebuilding. Later Datsuns with the L motors went to a bigger bolt later and did not have this proplem. I dont know A motor but assume the same Edited July 15 by banzai510(hainz) Quote Link to comment
PercyTheAce Posted July 15 Author Report Share Posted July 15 It hasn’t been lowered, it’s sitting at stock height on stock (albeit probably tired) suspension The bolt size that’s in there is a 10 with 1.25 threads I think? I can’t remember off the top of my head. I’m starting to think it might be a shitty casting on the alternator since it’s an oreillys remanufactured. It’s just odd since I’ve been driving a series cars for the last 7 years and this one in particular for the last 3 years. This is the first time I’ve had this issue Quote Link to comment
Stoffregen Motorsports Posted July 16 Report Share Posted July 16 (edited) Is this a cast lower bracket? If yes, drill all the way through it and use a long bolt with a nut and a lock washer. Use an old head bolt and you'll never break it again. Edited July 16 by Stoffregen Motorsports Quote Link to comment
