pidge Posted July 9 Report Share Posted July 9 Worth the elbow grease. Looks fantastic man Quote Link to comment
draekin13 Posted July 13 Author Report Share Posted July 13 Spent some time on it this morning before it got too hot (100+ high temps here for over a week now). New plugs/wires and the Weber installed, it is running but won't drop below 3k rpm. I'm afraid to let it run at that speed for too long so haven't spent much time on it but the idle adjustment isn't doing anything either. My nephew said he put a new fuel pump on it, is it possible it is pushing too much fuel? After reading a bit I ordered a fuel regulator as it seems like it isn't a bad thing to have either way. Truck is now jack stands, removed rear camper leaf springs and got the shock off of one side, they are old air shocks. Hoping tomorrow morning I can get the back end finished up and move to the front. Question for you guys, what's the best way to clean the wheels? I done some searching and only real recommendation I've seen is getting someone with a lathe or Eagle One Mag cleaner? Quote Link to comment
datzenmike Posted July 14 Report Share Posted July 14 If the choke is on there is a fast idle till it warms up. Have you let it warm up for 6-10 minutes? them blip the throttle and it should drop down. Is the throttle cable adjusted so there is some slack and it isn't holding the throttle open? It could run all day at 3k and no harm. Adding extra gas alone won't make it rev up. Quote Link to comment
Stoffregen Motorsports Posted July 14 Report Share Posted July 14 Try disconnecting the throttle cable from the carb and see the RPMs drop down. Quote Link to comment
draekin13 Posted July 14 Author Report Share Posted July 14 Thanks guys I will try these suggestions. Quote Link to comment
Stoffregen Motorsports Posted July 14 Report Share Posted July 14 Here's another thought. Did this carb come with the cable throttle linkage or did you swap it over? The DGV has a couple bushings and washers that are easy to mix up and if they do get installed incorrectly, the throttle can definitely hang up. Quote Link to comment
draekin13 Posted July 14 Author Report Share Posted July 14 Ok so I let it run for a little bit and rev never dropped. When I did blip the throttle the noise changed a little bit RPM did change a little. I took the air cleaner off and the butterflies are just free floating,when I hold the closed RPM do start to drop. It also smells like it is running very rich. Yes I swapped over the cable throttle linkage from the old one. It does seem to move freely with no issues and just a little slack that it is definitely staying off throttle. 1 Quote Link to comment
Stoffregen Motorsports Posted July 15 Report Share Posted July 15 The butterflies you see on the top of the carb are the choke plates. They shouldn't be free to do their own thing, but they will flutter a bit while the engine is running. Dumb question - did you try adjusting the idle screw on the linkage? Maybe I missed it, what carb is it exactly? Electric choke DGV? There is a fast idle adjustment on the side behind the choke spring thingy. Quote Link to comment
HntnFsh Posted July 16 Report Share Posted July 16 Numbers are even, straight across the odometer. I don't think it's rolled over. From what I've seen, when an odometer rolls over the Numbers usually aren't real even. Nice truck! 1 Quote Link to comment
