Gabriel Posted April 11 Report Share Posted April 11 Does anybody know what window crank handle could fit a 1970 521 besides the original? My original one lost all its teeth. I've looked for the original one, but couldn't find it. I wonder if the one from a different vehicle could work. Thank you all. Apologies if this has been talked about, I looked in the threads and couldn't find it. Quote Link to comment
banzai510(hainz) Posted April 11 Report Share Posted April 11 (edited) I usually swap from the passenger side till that one breaks on my 521 I had some spares but cant find them right now. If you find a swap let me know,I just awnsered my own question found this just now https://www.ebay.com/itm/225843612005?itmmeta=01HV7HRG5WH43NP0MZ18PKFN3D&hash=item3495540965:g:cYUAAOSwE2BlP5zV&itmprp=enc%3AAQAJAAAA8OsUC0B5%2BZKyCiAm4tiZiYctlS%2FtBTsBMWLY0UZKfThhRfiQd3k%2FgUFX4Gl1LQFSGu%2FBUkEYhK13XuR5Pjc33EDqElRANaAqQQ5mOeEwXq075IuGd8jxMma87fiAr2l7w00iIuat1834WeJb788w0Vzcgng2tRlqobWEn4UaCMXjIbQPotkqKyr7xohXUcLgXjNrft6hvWRaAHFhLGWhnGuOiuFRHXpigWGRrqSxyCee2TduKY4D2a7efxYqH940ZPdezA4jnlwCrvIsz4q2jl2iRx5a0LpzMvTfBXEui2m0caRW3YNRc--tXPx3y%2BiBdg%3D%3D|tkp%3ABFBMgIPi8dlj his link to his parts https://www.ebay.com/str/timevehicle/Datsun-Nissan-Retro/_i.html?store_cat=3879417619&_pgn=1 Edited April 11 by banzai510(hainz) Quote Link to comment
Gabriel Posted April 11 Author Report Share Posted April 11 Thank you so much Hainz. I'll check them out. But if you know of someone who sells metal ones that have that 70's look, please let me know. Quote Link to comment
datzenmike Posted April 11 Report Share Posted April 11 I remember mine looking more like these in chrome. Generally there is little to gain re inventing the wheel over and over. Hands are all similar size, door glass and regulators the same, so other than looks, the handle cranks will be close to the same design. Probably any Datsun hand crank will work. Get a pair and change both. Quote Link to comment
Gabriel Posted April 12 Author Report Share Posted April 12 Quote Thank you Mike. That's exactly what I have now. I found a post that says the 84 ford cranks fit Datsun. I found a couple in Amazon for $10. We'll see. I'll post the results. Quote Link to comment
datzenmike Posted April 12 Report Share Posted April 12 Same with oil filters. There are two different seal types on the ends and the threads are all the same. (probably different today) Ford 4.9 inline six fit Datsuns. Larger and cheaper. I think 318 dodge and probably SBC too. Quote Link to comment
banzai510(hainz) Posted April 12 Report Share Posted April 12 (edited) 13 hours ago, Gabriel said: fit Datsun fit 521 or 510 or both? Might make sense.The 521 has a screw s/body brake bots nutsand all threats on a 521 were SAE threads exept for the L16 was metric besides,the oil sender) Edited April 12 by banzai510(hainz) Quote Link to comment
NC85ST Posted April 12 Report Share Posted April 12 Many years ago mine broke and I used 620 handles and drilled the center for the screw. Worked great. Quote Link to comment
datzenmike Posted April 12 Report Share Posted April 12 Ahhhh good to know! Yes some, like old Dodges, had a screw most like my 710 have a clip. Quote Link to comment
