cgovia Posted December 18, 2008 Report Share Posted December 18, 2008 Put a set for titains on my 75 620 and the front center caps wont go on any ideas? Quote Link to comment
lynchfourtwenty Posted December 18, 2008 Report Share Posted December 18, 2008 maybe the cap goes in from the back of the wheel, im not familiar with the wheels in question but i have seen pleanty of wheels that the center cap goes in from the back.. Quote Link to comment
Llittle_Llama Posted December 18, 2008 Report Share Posted December 18, 2008 which titans? Quote Link to comment
cgovia Posted December 18, 2008 Author Report Share Posted December 18, 2008 the five spoke ones Quote Link to comment
cgovia Posted December 18, 2008 Author Report Share Posted December 18, 2008 tried pounding the dust cap no luck maybe I need a spacer? Quote Link to comment
Llittle_Llama Posted December 18, 2008 Report Share Posted December 18, 2008 are they bored? or is that not an issue with drums up front? Quote Link to comment
cgovia Posted December 18, 2008 Author Report Share Posted December 18, 2008 there bored the spindal cap is hitting pouned the cap to the nut but still it hits Quote Link to comment
cgovia Posted December 18, 2008 Author Report Share Posted December 18, 2008 same rims you have on your 620 DWNSHIFTER Quote Link to comment
Llittle_Llama Posted December 18, 2008 Report Share Posted December 18, 2008 i never had an issue with mine. that's really weird. redeye, bleach, where are you? you know more about these than I do. Quote Link to comment
cgovia Posted December 18, 2008 Author Report Share Posted December 18, 2008 thanks need I shine the bat signal for help? hahahahah Aloha Bro Quote Link to comment
Llittle_Llama Posted December 18, 2008 Report Share Posted December 18, 2008 and you have drums up front right? i know thats what was stock, but just checking. Quote Link to comment
cgovia Posted December 18, 2008 Author Report Share Posted December 18, 2008 Yep Quote Link to comment
79datsun620 Posted December 18, 2008 Report Share Posted December 18, 2008 no the DAT signal man.:lol: Quote Link to comment
Llittle_Llama Posted December 18, 2008 Report Share Posted December 18, 2008 half the day is gone and no one has said anything yet? guys, where are you?!? Quote Link to comment
]2eDeYe Posted December 18, 2008 Report Share Posted December 18, 2008 I was at my works Christmas lunch gettin fat... :fu: I never had a problem with the caps with or without spacers. Spray some colored paint on the dust cap and put the wheel back on with the center cap installed. It will leave marks in the wet paint where it is hitting. Have you tried it without the dust cap? Pics? :D Quote Link to comment
jefe de jefes Posted December 18, 2008 Report Share Posted December 18, 2008 use spacers. You might get away with breaking the 2 mounting tabs then glueing the nissan logo onto the cap. I think you have a 620 right? I'm running a spacer on my 521 and they work fine. You might need longer studs if you run spacers. Quote Link to comment
Llittle_Llama Posted December 19, 2008 Report Share Posted December 19, 2008 pics fo sho... Quote Link to comment
reese Posted December 19, 2008 Report Share Posted December 19, 2008 I had that problem on my 74 620, machined Titans no spacers and drum brakes. I had to mash the wheel bearing caps in, cut the tabs off the Nissan logo on the back of the center cap, machine .030 off the back of the center cap! and glue the Nissan logo on. Works fine now. What a bitch! Quote Link to comment
Llittle_Llama Posted December 19, 2008 Report Share Posted December 19, 2008 f all that, time for a fineline disc swap! Quote Link to comment
cgovia Posted December 19, 2008 Author Report Share Posted December 19, 2008 thanks guys Ill try some spacers then go from there Aloha Bros Quote Link to comment
]2eDeYe Posted December 19, 2008 Report Share Posted December 19, 2008 1/4 inch ones should do you good. ...and get some new dust caps. The caps spin and the nut doesn't ;) Quote Link to comment
cgovia Posted December 19, 2008 Author Report Share Posted December 19, 2008 shoots now I gotta find who sells them in hawaii or else gotta order from the mainland and get f%#ked by the shipping gods Quote Link to comment
79datsun620 Posted December 19, 2008 Report Share Posted December 19, 2008 speaking of spacers, should i run spacers with my titans on the rear. Quote Link to comment
jefe de jefes Posted December 19, 2008 Report Share Posted December 19, 2008 speaking of spacers, should i run spacers with my titans on the rear. you need to mount the wheels and check your clearances down there. I had to run them cause my tires were really close to my frame. Quote Link to comment
polini Posted December 22, 2008 Report Share Posted December 22, 2008 shoots now I gotta find who sells them in hawaii or else gotta order from the mainland and get f%#ked by the shipping gods wassup braddah i know rons sells the 1/4" spacers i juss got some for my 720 because i didn't bore out the back rims out on my denali rims an made up for the differenceon the drums. SPORT TRUCK CRUISE DEC 28 HOPE TO SEE YOU THERE. ALOJAHS. Quote Link to comment
