Chance Posted February 12 Report Share Posted February 12 hello just wanted to see some opinions on clutch kits. I'm torn between 2 the Clutch Kit LuK 06-022 which is widely available and unknown origin from my research around $100 or a exedy 06020HD made in Japan which Ive only found one and its $198. is it worth the extra money. I'm just looking for longevity. thanks Quote Link to comment
datzenmike Posted February 12 Report Share Posted February 12 LUK is South Korean as I remember it. They are or were alright. Quote Link to comment
banzai510(hainz) Posted February 12 Report Share Posted February 12 (edited) exedy sjould be cheaper than that/ My 521 was like 100$ but that was before Covid make sure you get the right one 620s had L16s 18s and L20s from 72 to 79 https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2499334.m570.l1313&_nkw=exedy+clutch+kit+datsun+620&_sacat=6000 Edited February 12 by banzai510(hainz) Quote Link to comment
datzenmike Posted February 12 Report Share Posted February 12 The above, has to be for a '73 with L16 and 200mm diameter disc. L18 and L20B were 225mm and won't fit. BTW the '74 L18 in the 620 was fitted with a 225mm 5 bolt flywheel, PP and clutch disc. Only used that one year till the L20B replaced it in '75. A 5 bolt 225mm clutch capable flywheel might be kind of handy for a performance 521/510/610 or 710 equipped with an L16 or L18 needing a stronger clutch if the Roadster ones aren't available. Quote Link to comment
Chance Posted February 12 Author Report Share Posted February 12 8 hours ago, banzai510(hainz) said: exedy sjould be cheaper than that/ My 521 was like 100$ but that was before Covid make sure you get the right one 620s had L16s 18s and L20s from 72 to 79 https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2499334.m570.l1313&_nkw=exedy+clutch+kit+datsun+620&_sacat=6000 yea I tried finding cheaper but there isn't. I'm buying it on eBay and the have the "confirmed fit" and the measurements are for a 200mm flywheel so I'm pretty sure it will fit if not I can just return it with the eBay "guaranteed fit" warranty. has your exedy done you good? Quote Link to comment
banzai510(hainz) Posted February 17 Report Share Posted February 17 (edited) On 2/12/2024 at 3:02 PM, Chance said: exedy done you good? yes they are fine, mostly made in Japan ,maybe the disc could be outsourced korea but they fine. Most kits are fine. But I would list Exedy Daiken on the Top. Asco (Aisin) these guys also Edited February 17 by banzai510(hainz) 1 Quote Link to comment
