72dyme Posted December 17, 2008 Report Share Posted December 17, 2008 Does the match box dist use the same cap and rotor, as the points style dist? thanks Quote Link to comment
datzenmike Posted December 17, 2008 Report Share Posted December 17, 2008 NO The cap is larger on the EI dizzy to space the wires further apart from each other because of the higher voltage. Quote Link to comment
datsunfish Posted December 17, 2008 Report Share Posted December 17, 2008 There are 2 types of points dizzy. The later larger one fits the same cap and rotor. Pretty sure anyways. Quote Link to comment
datzenmike Posted December 17, 2008 Report Share Posted December 17, 2008 (edited) Uh, now that I think of it, the early L20B dizzy with points, might have the larger size as well. The L16/18 only had points and were smaller Edited December 17, 2008 by datzenmike Quote Link to comment
72dyme Posted December 18, 2008 Author Report Share Posted December 18, 2008 but the rotors are thesame right, thanks for thehelp guys. Quote Link to comment
banzai510(hainz) Posted December 18, 2008 Report Share Posted December 18, 2008 Your thinking to hard just order a 79 200sx cap and rotor set. DONE!!!!!!!!!!! this is a matchbox set up. I like the Standard Motor Products Bluestreak as they are a blue cap and match nicely with the NGK plug wire sets NE64(is the part#) Quote Link to comment
