jluna94 Posted October 10, 2023 Report Share Posted October 10, 2023 Hi, I have a question on regarding the driveshaft. Is there a difference between the pl411 and the Rl411 driveshaft, or was the driveshaft used on both models? Thanks in advance. 1 Quote Link to comment
thisismatt Posted October 10, 2023 Report Share Posted October 10, 2023 I believe the slip yokes are different. Try looking on carpartsmanual.com https://www.carpartsmanual.com/datsun/bluebird-1965-1967/power-train/propeller-shaft/to-sep-65 https://www.carpartsmanual.com/datsun/bluebird-1964-1965/power-train/propeller-shaft Quote Link to comment
bananahamuck Posted October 17, 2023 Report Share Posted October 17, 2023 Slip yokes are exactly the same but the PL shaft is longer .. The RL has a larger H190 rear end which is longer so shaft is like 3/4” shorter . Slip yokes will fit almost all later model Datsun transmissions . I’m sure Flange that bolts to rear differential is same also. Quote Link to comment
