411 Driveshaft
jluna94
  • Replies 2
Slip yokes are exactly the same but the PL shaft is longer .. The RL has a larger H190 rear end which is longer so shaft is like 3/4” shorter .
Slip yokes will fit almost all later model Datsun transmissions . I’m sure Flange that bolts to rear differential is same also.
