Veraciousreasoning Posted September 25, 2023 Report Share Posted September 25, 2023 Hey all, Got the Weber fully installed but I did something stupid. I forgot to take pictures of the wiring and forgot where the wires go. It has an electronic choke and I am wondering what color wire off the distributor so I wire to the electric choke. Quote Link to comment
banzai510(hainz) Posted September 25, 2023 Report Share Posted September 25, 2023 I dont think the wire comes off the distributor. should be ez to figure out. turn key on off and find the wire that gets 12volts on /off but remeber unless you ordered the 32/36 DGEV -IC with selinoid cut off you could have run on issues. as the stock carb has the cut off and also the electric choke wire datzenmike will know which wires Quote Link to comment
datzenmike Posted September 25, 2023 Report Share Posted September 25, 2023 Idle cut is Brown and choke heater is Blue/Red and both wires come from the direction of the distributor. Idle cut has power with ignition on and choke heater only when engine running Quote Link to comment
Veraciousreasoning Posted September 25, 2023 Author Report Share Posted September 25, 2023 2 hours ago, banzai510(hainz) said: I dont think the wire comes off the distributor. should be ez to figure out. turn key on off and find the wire that gets 12volts on /off but remeber unless you ordered the 32/36 DGEV -IC with selinoid cut off you could have run on issues. as the stock carb has the cut off and also the electric choke wire datzenmike will know which wires Yeah I found the old carb and traced it. Blue goes to the electric choke Just gotta figure the second wire and where it goes Quote Link to comment
Veraciousreasoning Posted September 25, 2023 Author Report Share Posted September 25, 2023 41 minutes ago, datzenmike said: Idle cut is Brown and choke heater is Blue/Red and both wires come from the direction of the distributor. Idle cut has power with ignition on and choke heater only when engine running Thanks mike Quote Link to comment
