Veraciousreasoning Posted September 17, 2023 Report Share Posted September 17, 2023 Hey all, So I'm almost finished with my weber install and gonna try to get her running today. I'm connecting the throttle cable and I'm noticing there is a bunch of play in it. I out everything that they gave me on but its still got a bunch of play. Any suggestions Quote Link to comment
Stoffregen Motorsports Posted September 18, 2023 Report Share Posted September 18, 2023 That's the generic throttle pull. There are other styles. It is possible to use the piece off the original carb, just make sure that it's clocked right and that it doesn't bind the throttle shaft when tightened. Quote Link to comment
Veraciousreasoning Posted September 18, 2023 Author Report Share Posted September 18, 2023 31 minutes ago, Stoffregen Motorsports said: That's the generic throttle pull. There are other styles. It is possible to use the piece off the original carb, just make sure that it's clocked right and that it doesn't bind the throttle shaft when tightened. Got a video that explains that Quote Link to comment
Stoffregen Motorsports Posted September 18, 2023 Report Share Posted September 18, 2023 You do, or is that a question? No video. No pics even. If you take the stock linkage piece off, and look at how it is slotted to fit the shaft, I believe the clocking is close enough to make it work. Quote Link to comment
Stoffregen Motorsports Posted September 18, 2023 Report Share Posted September 18, 2023 I grabbed this off the web. Not Datsun but the idea is the same. This is a Datsun, but a 1200. Quote Link to comment
Thomas Perkins Posted September 18, 2023 Report Share Posted September 18, 2023 (edited) I guess a 80 and 85 are totally different.The one on mine is totally different than the Webers now.Long ago,I bought my first Weber from from North American Weber.I think it was the same people that sold the Redline"s.Mine back then came with a Idle cut off solenoid.They have the big jets on them 0.155.I dont use A Weber one,couldnt get it to work,I use a Empi with their jet and O ring ,works perfect I do have a extra one too.That is how they sold them.The linkage on those are way better than the now Redline"s.You can't buy that type any where.I do have extra springs and the lock down washers.Also extra gaskets.That Weber came with a black choke.Redlines come with white Choke.The Weber I have now is a real Redline.I bought it in 2016.The gaskets need changing every so often.You can see the gas stains on the out side.I never ever had to adjust the mixture screw.I sold the old Weber on 720 World back in 2016.I got 120 bucks for it.I sold it with the Redline throttle stuff.I do have a you tube video with the North American Weber.If you look at the serial numbers to the right at the base.and you have a 32/36 electric choke.It will have DVAG stamped into it cause,they use the same body but that is for a water choke for some reason,they Stamp them DVAG.The V stands for right handed and the DF one's stand for left handed with means the throttle turns counter clock wise.Who all knew this.Did you just buy the carb,but not the kit.A lot of different variants with Webers.Best to buy Weber with kit.Some linkage are manual.Ifbyou tighten that linkage nut to tight it will cause it to stick and idle high also good to spray the linkage at the fast idle.When I change gaskets ,I have too or it will stick. Edited September 18, 2023 by Thomas Perkins 1 Quote Link to comment
Veraciousreasoning Posted September 19, 2023 Author Report Share Posted September 19, 2023 I bought the kit. They forgot to out the lock tab in it. Ordered a bunch to have on stock Quote Link to comment
Thomas Perkins Posted September 19, 2023 Report Share Posted September 19, 2023 (edited) Yeah,I have a bunch of them.Dont tighten the nut to tight. It will cause the throttle to not return and idle high.Them lock tabs break real easy.Since you bend them.I have extra nuts too.Dont forget to set your fast idle to 2000 rpm's.Best to do when engine is cold but can manually do it hot.The screw is by the choke in a tight spot.Takes a flat head screw driver and a mirror.Spray some WD-40 on the linkage there. Edited September 19, 2023 by Thomas Perkins 1 Quote Link to comment
Connor Snyder Posted September 20, 2023 Report Share Posted September 20, 2023 That looks totally foreign to me when I put my weber on my 82 we flipped the linkage on the carb and used the stock throttle cable bracket and it's worked totally fine. I didn't even understand how they wanted me to use the new bracket they supplied. Although I think they supplied me with a bracket for an l series engine because the bracket was the wrong orientation for the z series. 1 Quote Link to comment
Veraciousreasoning Posted September 21, 2023 Author Report Share Posted September 21, 2023 On 9/19/2023 at 12:16 PM, Thomas Perkins said: Yeah,I have a bunch of them.Dont tighten the nut to tight. It will cause the throttle to not return and idle high.Them lock tabs break real easy.Since you bend them.I have extra nuts too.Dont forget to set your fast idle to 2000 rpm's.Best to do when engine is cold but can manually do it hot.The screw is by the choke in a tight spot.Takes a flat head screw driver and a mirror.Spray some WD-40 on the linkage there. Yeah I'll make sure to do that. Quote Link to comment
Veraciousreasoning Posted September 21, 2023 Author Report Share Posted September 21, 2023 3 hours ago, Connor Snyder said: That looks totally foreign to me when I put my weber on my 82 we flipped the linkage on the carb and used the stock throttle cable bracket and it's worked totally fine. I didn't even understand how they wanted me to use the new bracket they supplied. Although I think they supplied me with a bracket for an l series engine because the bracket was the wrong orientation for the z series. I'm just following their manual for install. It fits just has play in it. The loxktabs should he in tomorrow and I can finally install it fully and get her turned over. 1 Quote Link to comment
Connor Snyder Posted September 21, 2023 Report Share Posted September 21, 2023 15 hours ago, Veraciousreasoning said: I'm just following their manual for install. It fits just has play in it. The loxktabs should he in tomorrow and I can finally install it fully and get her turned over. I honestly didn't understand the instructions so we just kinds figured it out as we went. 1 Quote Link to comment
Veraciousreasoning Posted September 21, 2023 Author Report Share Posted September 21, 2023 2 hours ago, Connor Snyder said: I honestly didn't understand the instructions so we just kinds figured it out as we went. Yeah it was kind of wonky but I figured it out lol 1 Quote Link to comment
